Results 1 to 23 of 23
Thread: ARTHRITIS
    Oct 2013
    rome new york
    Default ARTHRITIS
    So being with the older generation of this sight figured it would be good place to ask this question.
    i"m Have osteoarthritis in many parts of my body (recently in my hips). Having a hard time walking any distance without them aching and getting stiff.
    Orthopedic Dr. prescribed Tramadol and Gabapentin. Long story short i'm not big. on pain meds and nerve meds.
    Anybody have natural remedies that may work.
    Really takes it's toll on my hunting and walking. And no i won't take the spyder in the woods
    Thanks
    Jul 2016
    Arizona
    Default Yes
    I am in my 70s with fairly bad arthritis and like you I will not take any drugs where one of the side effects is death!! The one natural remedy that really works for me is turmeric. I buy it from Amazon and take one teaspoon mixed with water every morning. It tastes terrible but just gulp it down. You can also buy it in capsule form but much more expensive.. Has almost completely eliminated the pain and greatly increased my mobility. Good luck.. I used to share your pain!!!
    Active Member sylvester's Avatar
    Aug 2017
    arkansas
    thanks for the info i'm in the same shape
    Active Member Samson's Avatar
    Aug 2016
    Prescott Valley , Az
    Tumeric, Ginger Root, Bromelain. Try to stay away form the Tramadol as its a narcotic. Just had my second knee replacement, no pain meds after day 3. I am using these 3 to help keep the swelling down.
    Default One more....
    For the Tumeric... Have cooked with it for years and now take the pills, which you can get online cheaper, and make a balm/salve and tincture out of a medicinal plant that works wonders. But it depends on where you are and if it is available....
    ​2012 RS sm5
    Dec 2008
    Syracuse, NY
    Here:
    http://www.ayurvedicnaturalcure.com/...steoarthritis/
    Some natural remedies have been mentioned already.
    Sep 2014
    USA
    Tramadol is heavy duty Tylenol. Don't think its a narcotic.
    I been taking Humira and helps my specific Arthritis issue and Chrones disease. If not I think I would be in a wheel chair by now.
    I hear apply cider vinegar does a lot of things that I may try at some point.
    Jul 2014
    Nowhere
    I'm using Systemic Enzymes like Wobenzym N.
    https://www.gardenoflife.com/content...ct/wobenzym-n/
    I can tell when I've been off it (put my bottle in a very safe place and was too stubborn to buy another until I found the open one). Working outside (check in bees, clean chicken coop, generally get the place ready for freezing weather) has left me with cranky, stiff hips. I started to pack for my turkey day trip and found my Wobenzyme. I'll be mo betta in a couple of days.
    "If you can't be a good example, then you'll just have to be a horrible warning." Catherine Aird
    Dec 2013
    Tramadol is heavy duty Tylenol. Don't think its a narcotic....
    Sorry, but Tramadol IS very much an opiod narcotic analgesic; it's a synthetic drug that works in a similar way to Codeine, but it can increase your risk of seizures & if used for a long time as a treatment for chronic pain, it is also prone to inducing irreversible 'spastic tics' which you will have for the rest of your life, even if you do manage to get weaned off the drug! Bearing in mind that I'm a long term severe pain sufferer & NOT a physician, I believe it's pretty good stuff when used for short term moderate pain; but not so good for severe or long term pain or arthritic pain, largely due to the potential side effects....
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Very Active Member NautiBrit's Avatar
    Jun 2008
    Buckeye, AZ
    Thank you all for the suggestions. I've had a hip replaced, need the other done, as well as both knees as a result of playing football (soccer) well into my 60's. Getting rid of the pain is my #1 priority, getting back on the pitch would be a Godsend.
    George
    2017 BMW R1200R
    Sep 2014
    USA
    Tramadol is a narcotic-like pain reliever
    I have used it also and along with other pain reliever's .
    I was lucky enough to have my pain and symptom's held at a tolerable levels for now but some days can be a bitch moving around but have to keep moving.
    Dec 2013
    Tramadol is a narcotic-like pain reliever....
    Yeah exactly, it's a synthetic Opiod pain medication that works just like all the other opiates, opium derivatives, & semi-synthetic narcotics by acting upon the opiate receptors in your brain & as a result will get you arrested if you sell, possess, or use this type of drug without the appropriate controls or authorities.... cos their effect is narcotic and addictive if not consumed by fighting pain.
    Ask your Doctor or Pharmacist, I'm pretty sure that in both your country and mine, Tramadol is a controlled substance that is listed as a narcotic drug.... at least it was when I visited a couple of years back & had to get special permission & documentation to posses, carry, & use the Narcotic Pain meds including Tramadol that I had been prescribed. Altho I was told then that despite all the above, up until about 2010 or so Tramadol was considered a 'lesser narcotic' & an 'opiate agonist' in just a few of your states; but shortly before my travel they all came into line with the rest of the world & recognised it as a Narcotic Analgesic & so required all the extra paper work & approvals.......
    So just like the saying goes about that other well known stuff; if it looks like it, it smells like it, it tastes like it, and it even acts on your body/brain like it, then it probably is ......
    Idaho
    CVS Caremark lists it in their formulary as a Tier 1, generics, Opioid Analgesic, same group as methadone and morphine.
    2014 Copper RTS
    Jun 2014
    People's Republic of NY
    Informative thread, thanks
    committee for postings
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    Quote Originally Posted by bmccaffrey View Post
    Thanks
    A little background, I'm an RN, getting up in years and have had both hips replaced about 10 years ago.
    Tramadol will help with the osteo pain. Not so sure about the gabapentin which as you state is for nerve pain. If you have some type of nerve related pain or disease such as diabetes then that would make sense. Even if you don't feel it, stay off the bike or dont drive when you take the tramadol, it could make you liable for a DUI if for some reason you had an accident and they took a blood test.
    You could try one of the NSAID's like ibuprofen or naproxen, they work by reducing inflammation, which will in turn reduce the pain you feel. Just keep in mind that long term use isn't good for kidneys or liver. But do what you need to keep going.
    You may want to consider joint replacements. Talk to your Ortho about it, but I imagine its already come up. Recovery is about 3 weeks if they do the anterior (front) approach. It makes a big improvement in overall quality of life.
    2010 RT SE5 , Black
    Captain Morgan Rum: it doesn't make me feel any better, but I just don't mind it as much!
    Very Active Member Orange Spyder Man's Avatar
    Sep 2014
    3rd ROCK FROM THE SUN !
    my doctor gave me a prescription of
    gabapentin for sciatic nerve pain and told me not to drive or operate machinery while on this drug.. I gave the piece of paper with the prescription back to him and said .. '' NO THANKS "
    osm
    Invalid Emails
    Apr 2017
    AZ
    Tried both Gabapentin and Tramadol for back/hip pain and neither had the slightest impact. Currently trying Tumeric but it isn't doing squat either. I have to take two big doses of a narcotic to have any effect at all and then it does not last but a few hours. Doc's say surgery is risky and doesn't have positive results most of the time so I am just dealing with the pain. Sucks!
    washington state
    Sorry and I feel bad that some of us have health issues. Getting old is part of it. Lets not forget that "we are what we eat". Doctors give you med to take to make you feel good but DO NOT tell you the cause. We must know our self what make us sick and take action.
    I like the non narcotics remedies. Tumeric , Ginger tea.
    Castor oil is been around since the time of Christ and it's the miracle oil.
    Apply castor oil on painful areas with heating pad over night.
    2012 Spyder RT SE5 Brake pedal mod
    Sep 2014
    USA
    Prune juice ! Solves all kinds of ailments.
    A good cleansing does some good too
    Invalid Emails
    Oct 2014
    Calgary, Canada
    Had two total knee replacement surgeries and I HIGHLY recommend that solution ... if the pain gets bad enough.
    No one can tell you when that pain is so bad that you will put your self through such surgeries as cutting the top and bottom off of your knee joint and replacing the joint entirely with a metal alloy ... separated by several months of physiotherapy only to do it all again a year later on the other leg.
    But that said it is a 100% fix.
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    MK-7 which is a K2 vitamin. Works great on inflammation. Grape seed extract works for inflammation too. You also might want to check out CBD oil. Here is a good place for high quality stuff.
    https://www.cwhemp.com/customer/acco...=5a1382258fb7e
    AKA Jud Smales, Four Year Spyder Ryder!
    "Quando Omni Flunkus, Moritati"
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Driver & Passenger Gel Pads in Seat
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Break Stripe Kit from Wrap My Spyder
    2016 RT-S , stock not yet Pearl White
    Oct 2013
    rome new york
    Have tried tumeric didn't help. Thinking cbd oil a try.
    Prescriptions sit in cabinet untouched. New orthopedic Dr. Dec 3
    primary tomorrow . See if he has any answers.
    Thanks for all your help guys. Lots of good answers.
    Can we put them all together in one mix and call it SPYDER MIRACLE LOL
