Frunk Power Connector
Attempting to add 12 volt power to frunk on 2013 STS. Purchased outlet from BRP, pn 0000754610, mechanically, fits the frunk.
Problem is, I cannot find the.power connector. Frunk is removed in picture. Anyone have any idea where this connector could hide. According to the service manual it should be a 2 conductor, 16 gauge, violet/yellow, black. It appears to be part of the main cable harness, but I am unable to locate this connector. Any idea where to poke further?
Its right above the bolt on the right side of the picture--- Inside the boot
Its right above the bolt on the right side of the picture--- Inside the rubber boot that is doubled back and has a zip tie holding it out of the way ready for you to clip it loose and attach! after you slip the connectors onto the outlet prongs, stretch the boot over the back of the outlet for a watertight seal
Reason: add boot
07 Shadows, Aero, Spirit gone but not forgotten
03 Harley Sportster, 07 RK moved on
11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
There you have it...
it is keyed power but if not mistaken you can change the fuse position to make it constant power. Maybe some one will confirm if not mistaken the 6 and 7 position. Mine I never changed ...
2012 RS sm5
