Results 1 to 25 of 31
    Member Bad Grandpa's Avatar
    Apr 2016
    Monrovia,MD
    Default LOADING spyder in Toyhauler
    Anyone solved issue of loading Spyder in these TALL, 30", toy haulers, and backing in only way it fits in my 20' toy hauler!
    Default LOADING
    Quote Originally Posted by Bad Grandpa View Post
    I have a flat bed toyt.pk-up .... I put my RT on the bed .... It is a 28" bed height ... I use 10ft. ramps .... my center ramp is covered with 26ga. galv. sheet metal that I have made into a " cheese grater " ie., I took a large nail and made dimples in the sheet metal ( a lot of them ) I flipped it over and screwed it to the ramp .... I have never lost traction even in pouring rain .... I can stop and then continue ..... I have never tried to go up in reverse ..... good luck, ...... Mike
    Active Member LJspydee's Avatar
    Nov 2012
    Casa GrandeAZ/formally WaterlooIA
    Default Loading Spyder into a toyhauler
    We have a toyhauler with a high deck and a steep ramp door. I installed a winch in the toyhauler and pull our Spyder RT in backwards. When the nose gets close to the ground I put ramps behind the front wheels. Once the nose clears the ground I finish loading. I found out that the rear wheel losses traction if I try to back in under engine power at slow speed. I also back in to allow room up front to stand my small Spyder trailer in the toyhauler. Gotta carry all the toys!
    2013 Silverado 2500HD Duramax
    2017 Honda Pilot
    2018 Maverick Trail 1000 DPS
    2015 RTS SE6 Intense Red Pearl
    2014 35' Keystone Fuzion Impact Toyhauler
    Ultimate Seats passenger backrest, Adjustable wind deflectors, Minitrailer USA trailer, Can Am driver backrest, Corbin passenger armrests, after market hitch, DIY bump skid, LED turn indicaters, cup holders, frunk decal stripes, DIY GPS mount, DIY Gopro dash mount, aux 12v & USB outlets, DIY belt rock shield, BajaRon swaybar, frunk 12v outlet
    I've got two seven-foot ramps, that I place a bit more than halfway up my Outlaw's ramp. I back the bike up into the rig. The extra ramps pick the nose up before it touches down, and it still has the front-end elevated just enough to less the breakover angle.
    No muss: no fuss!
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    Default Loading my RT in our RV
    The additional ramps lift the front so it doesn’t rub when the back end starts up the ramp.
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    Aug 2012
    CO
    I forget how high the floor was on our old Keystone Fuzion, but the only time I scraped the nose was one time on a weird sloping campsite. On level ground the RS made it in nose first every time just fine. We had an 8ft ramp door
    JLohPhotos
    2008 GS , Millennium Yellow
    Apr 2017
    North Central Florida
    Well I guess I got lucky.
    My RT goes into the 36 foot Outlaw just fine. Forward.
    IF.....it is on level ground AND I remember to take the anchor out of the middle track first.
    If the end of the ramp ends up lower than level, then it will drag on the belly when trying to go in.
    Same thing with leaving the middle anchor in place.
    Do you have an Outlaw 36T?
    The Missus and I were thinking about trading for one of those (a 2012 model year rig,)
    Nov 2013
    Oro Valley Arizona
    I cut a piece of 5/8 plywood in two and the cut it to length. 2 ft X 7 ft with two short pieces of 4 X 4 under the back of the ramp and use the 2 X 7 foot
    plywood as an extended ramp and drive straight in.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Apr 2017
    It is an '07 3611. Don't know what the "11" stands for.
    It is on a GM Workhorse chassis.
    I like it well enough. So far it has had no more problems than the 10 year old Winnebago that I traded in.
    I expected to have to put some money into it.
    Sweet rig!
    Active Member Freegle's Avatar
    Feb 2016
    South Carolina
    Default Use a portable wench.
    I have a 2015 Forest River Vengeance V25. The only way my 2012 RTS will fit into the camper is backwards. In this camper the storage area is part of the living quarters. I have been backing the Spyder up the ramp into the camper. The issue I have is that once the rear tire hits the flooring in the camper the rear tire starts to spins. It would be almost impossible if the tire was wet or in most cases snady. I have purchased a portable 12v Marine Winch (https://www.harborfreight.com/2000-l...nch-61876.html). The winch is around $80 and is portable so it can be used in other places and comes with a detachable plate that has a cutout that can be placed over a ball of a hitch which servers as an attachment point for the winch.
    I plan to use a tie down in the floor and use a large Carabiners, along with the detachable plate that comes with the winch to create an attachment point for the winch. I have a webbed towing strap that I will run through the passengers handles of the Spyder and connect it to the winch cable. This should pull the Spyder up the ramp and into place without doing any more damage to the flooring in the camper. Once the Spyder is loaded I can pack everything up and store it away. No ugly winch in the middle of the kitchen (Keep Wife happy). I saw this in an earlier post about toyhauler and they had great success with this method. It would also be a great help if one would have a problem with the Spyder and have to load the Spyder without engine power.
    2012 RTS
    2012 RtS M5 , Stock Homemade Metallic Silver
    The garages in the Thor Outlaws have a rubberized flooring: excellent traction!
    Apr 2017
    Wait.....I thought you JUST GOT a toy hauler a couple of months ago.
    Did I miss something ??
    We did...
    We got this one:
    But were considering moving to a larger rig...
    Jun 2017
    Texas
    Default Both are very nice ..!
    We did...
    We got this one:
    hopefully you don’t get “soaked” on the Trade ..! Both of these are really nice ..!
    2016 RT-Ltd
    Bajaron swaybar
    brake modulator
    missing belt guard
    Baker air wings
    Apr 2017
    Given my previous comments about a Spyder being a really tight fit in that C........
    AND the fact that I just realized that you do not now actually HAVE a Spyder to test the fit.......
    I think if you can easily afford the upgrade you really should. You will be happier in the long run.
    Unless the larger overall size will be a problem, of course.
    Mar 2011
    gaines Michigan
    Quote Originally Posted by jaherbst View Post
    Jack
    When you did this Jack, it changed the angle enough so you didn't catch when you backed out?
    You can also use your leveling jacks to raise up the front of your RV. That'll also change that breakover angle.
    I could actually pick the front wheels of the Outlaw off the ground: no hang-ups ever!
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by ijon1 View Post
    That is correct. Also very important to have the Toy Hauler disconnected and the hitch jack all the way up or nearly so. It drastically reduces the angle of
    the loading ramp.
    Jack
    2015 BMW R1200R LC
    Jack,
    How is that new rig working out for you?
    Ours is scheduled to start construction on November 13th...
    Dec 2015
    Oakley Utah
    Are you talking about the deck height of 30" ?
    2014 RTL Platinum
    That is what he is talking about...
    Ours was actually 32" high...
    Nov 2016
    Ontario
    I have a 19 foot roadmaster toy hauler and the rt spyder goes in perfect these toy hauler are low
    2016 Rt , Pearl white
