Results 1 to 7 of 7
    Feb 2016
    France
    Default Stiff RT mirrors
    My RT 2014 mirrors are very hard to adjust, does anyone knoe a fix for this, I tried getting some wd40 and fine oil on the ball the mirror swivels on but no improvement. I imagine there is a screw underneath the glass, but I imagine the glass is made to break the glass if you attempt to remove it.
    any input appreciated
    Thanks
    Alex
    2014 RT Std
    Floor and Highway Boards
    50$ GPS connected to oem loom
    Trunk & Frunk Liners and lights
    Frunk and dashboard power outlets
    Front supension LEDS
    Cup holders
    Glovebox light
    Turn signal LEDs in mirrors
    12 volt coffee maker
    Passenger hangrip muffs
    Ignition lock light
    Windscreen wiper/ baguette holder
    If I wasn't so cleverI wouldn't need to be so good looking.
    2014 RT , Black
    It's just a case of grit your teeth, and tough it out: there's no adjustment in them.
    Default RT MIRROR ADJUSTMENT
    Quote Originally Posted by agedbikeman View Post
    Thanks
    Alex
    After using the WD-40 and found No difference , consider your-self LUCKY ...... you Didn't get any on the PLASTIC ball and socket ..... #1....WD-40 might be mildly corrosive to plastic ( long term ) ..... #2.... could very possibly make that connection TOO loose and then how would you fix that ???? ...... The trick to adjusting is ....Don't try to do it while riding , because the most effective way to adjust them is by squeezing the mirror glass with your thumb while pushing on the outside of the Housing ......... PS , there is very very little adjustment in the unit it-self ......it is designed this way ..... good luck .... Mike
    Very Active Member jthornton's Avatar
    Feb 2013
    Poplar Bluff, MO
    They are adjustable and yes the mirror will break if you try and remove it. The adjustment range is about 1/2" in any ONE direction. The ball and socket is plastic so WD40 or any oil like product may make the plastic swell making it even worse. The spring and ball above inside the mirror is metal but you can't get to it unless you break the mirror. You might try a silicon spray...
    JT
    Aug 2008
    MA & NH
    Try sobering them up.
    Feb 2016
    France
    Default Stiff RT Mirrors
    Quote Originally Posted by jthornton View Post
    JT
    Yet another crap design by BRP, probably designed by the janitor in his lunch break
    2014 RT Std
    Cup holders
    Glovebox light
    Ignition lock light
    2014 RT , Black
    Would you rather that they loosen up, and not hold their positioning?
    Once you get them where they need to be: you'll never have to move them anyway!
