Interesting....
Which hours...?? trip hours or total engine operation hours..?? The trip hours you can reset, the total hours of operation has to be done with BUDS and I don't know for sure about it. I don't do dealer service so when they check my system, they have told me that they cannot reset the hours since the last service, but I don't think that is the same as the total hours. That one is like the total mileage....
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
2012 RS sm5
Originally Posted by Chupaca
Wonder if there is a max on the system and you reached it... you need to find someone with BUDS and see if they can do something about it. Would be strange if only that feature failed. Maybe the sensor has gone out if it has one... The one guy that checked my system only said that because they did not do the service they could not reset the clock since the last service. Something that shows up when checking the system with BUDS.
The dealer did hook it up to BUDS but nothing happened......oh well, keeps the hours down
Hours Stuck
Dealer did some work this past April on my 2012 RSS-SE5. On return home noticed that my total hours is also stuck on 1070.9. Trip hours is stuck on 0 and neither will reset!!
Wow..!!
Now I'm starting to wonder...you two are nowhere near each other so it looks like a BUDS system glitch of some sort...I would check with another dealer and see if this is everywhere.. do either of you remember what was on the clock when you went in..?? I have 891 on the clock and 38,373 on the mileage but as I said no one messes with my system....
2012 RS sm5
Stuck
I have the mileage recorded but no hours- no idea.
Engine Hours
My 2015 F3-S has both a trip hour meter and the total engine hours. I believe that 'basic' display/cluster was used on the base RS/ST and is still used on the F3/F3S.
Marilyn 2023 RTL Red
John 2023 RTL Black
previous:
2015 RTS SE6 Red
2015 F3S SE6 Silver
2011 RT SM5 Silver
2013 STS SM5 Silver
"common sense will prevail....but we see no sign of that"
Pogo says elsewhere: You will find it difficult to get many more hours up. The counter freezes at (from memory) 1070.9 hours. It is a 16 bit counter counting minutes of operation. When it reaches 65535 (the maximum count for a 16 bit counter) it freezes.
Thanks Pogo.
