Hot thighs
I am new to Spyder lovers and have recently purchased a 2014 RT S. I'm really enjoying my Spyder but today I rode several hundred miles and I had a problem with my thighs getting really hot right by the glove box. What can be done? Any help is appreciated.
What kind of pants are you wearing? A good thick pair of jeans with no nylon in them should keep you cool.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I love good looking hot thighs---I have a very short attention span & leave my nylons out of this conversation..
Darrell
Are hot thighs accompanied by exhaust popping on deceleration, or increased exhaust smell while idling? Might be a failing exhaust gasket.
JLohPhotos
go to www.airhawk.com and buy the "R" Version Cruiser seat cushion and solve your problem, they have a 60 day full refund if it don't solve the problem
Cruzr Joe
HOT THIGHS
I had the heat kit installed on my 2011. Although it was designed for the 2013's I believe it fits your 2014 as well.
it stopped a lot of the blasting hot air that was coming up between the seat and the glove box.
The kit itself is under $70.00. I paid 1 hour labour for the install. Well worth the cost to me.
Greg
2015 RT Limited (White)
Baker Air Wings
On warm days I would open my Baker Wings and cut a breeze directly through the Hot Thigh area. Cold weather I shut them down and I picked up extra heat from the motor.
http://www.bakerbuiltairwings.com/pr...=1SPYRTACRAWUP
Originally Posted by DGoebel
Though not required by '14's and later, I've heard of several who installed the '13 Heat recall vents which helped push more cool air under the side panels, making them cooler, the scoop inlet under the arrow below.
This is the solution. Did it to both of my 2014RTLs. It comes with heat shield material for that area your thighs are closest to. Works.
2014 RTL Platinum
Grump, I have a 2016 RT-S and have the same problem here in Virginia, even today. That should change for the next 6 or 7 months in two more days.
You're in Arizona, you're screwed.
Part Number for kit?
Do you have a part number or link for 2013 Magnesium STS??
tia,
Originally Posted by spyderfish
Do you have a part number or link for 2013 Magnesium STS?? tia,
I think it is only available for the RT (any color because the kit parts are black)
2014 RTL Platinum
tia,
Sorry Tia but mine is an RT. Not sure what number you need for the STS
Greg
I have a 15 RTS mine was warm in an around glove box. My thighs and crotch were warm. I got the scoops and now it's always cool in any temp. They look cool to.
You're right about the scoops looking cool. A guy with a 2014 RT came up to me at a coffee shop the other day. He wondered what year my Spyder was because of the scoops.
I explained it to him and he said that he doesn't care about the acoustic panel modifications but he's going to order the kit so he can have scoops.
His spyder is white so it should look pretty cool.
Greg
I have a 2014 RTS-SE6 and I haven't had that problem.
I wear jeans when riding.
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
No, I was riding across the desert and it was 105deg.
Try the scoops!
I installed the scoops (pics in another thread) on my 2016 RTS. Big difference in heat near the glove box. The kit is only $50 (which is amazing). However you gotta drill holes in your tupperware. You'll probably miss one or two spots, but they get covered up. Also the plastic is cheap looking, I used black plasti-dip to paint them before installing. You can see the shiny plastic above - was already scratched up with tiny scratches out of the box. Kit comes with stick on insulation for the tupperware also, that helps keep your legs cool. Works great so far, glove box stays same temp as outside now instead of baking my phone!!
Details in this thread: http://www.spyderlovers.com/forums/s...ghlight=scoops
Steve
