On my Spyder; Limp Home Mode, DPS failure, VSS, and CEL on the way home tonight..
Well.. it happened! After 10,500 miles with no issues...
On the way home tonight heading north on Hwy 196, the engine began sputtering, and all of these warnings came on. I was able to get it pulled over into a parking lot, and I could feel that the DPS wasn't working.
I shut it off, and let it sit a couple of minutes. I restarted it. And, everything was fine once again. DPS was working, as well. For the remaining 15 miles back to the house, everything was fine - like it never even occured.
This past weekend, I had the new back tire installed, and new brakes all around. Everything was just peachy! And, now .... this!
I emailed my dealer. I'm sure they will just asked me to bring it in..
- Greg
2013 RT-S Circuit Yellow Metallic
Previously owned...
2008 Spyder GS (Full Moon) 32,800 miles
2011 Spyder RS-S (Magnesium/Black) 31,230 miles
Alignment Specialist
Rut roh...something was 'dinged' with the changes you made...I'm sure the dealer will figure it out...what about the sensors on the rear wheel that were obviously tinkered with when you replaced the tire? Also, why change the tire at 10k?
Bone Crusher
If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
Mod Maniac
Loose relays. Take 'em out, re-seat them.
ata = allergic to asphalt
My mods: https://www.spyderlovers.com/forums/...ead.php?t=5753
There are two kinds of people: (1) those who can read, reason and apply the experiences of others; and (2) those who just have to pee on the electric fence. ataDude, 2009
My Spyder:
Put a piece of foam inside top box
Only change, I made was the Hindle, several hundred miles back. The tire was due for replacement; way into all wear indicators. They replaced the brake pads, and changed the oil. All for $670.19 .
I rode 186 miles yesterday. Beautiful! Oh well... We will see what they say.
- Greg
Previously owned...
A nice fix like that would be great! Thanks for the tip!
Where might I find the relays?
- Greg
Previously owned...
Mod Maniac
Front fuse box.
My Spyder:
Front fuse box.
Well; I have seen that many times! I'll address that.
Many thanks!
- Greg
Previously owned...
And, a piece of foam! Got it!
Thanks!!
- Greg
Previously owned...
I just went out and checked the relays. The main relay was, in fact, loose. I re-seated it, and put some mini bubble wrap in the top, and put it back on.
- Greg
Previously owned...
Dang....Hopefully it was just the relay like i have heard many times from around here.
Happy SE5 Owner!!!
Silver/Black SE5 - Trunk Liner, 1" riser, 12v, Kuryakyn ISO Grips, 5" Kewlmetal Pullback Bars, Kewlmetal Console, Zumo 450, Ipod, Kewlmetal Highway brackets with Wing pegs, Triple Play, Wizard Light LED's, Corbin front/rear saddle with Backrest, Nelson Rigg CL950 Saddlebags with CL800 Tote Bag, CalSci Medium Windshield.
I went out after work yesterday afternoon, and rode about 50miles. No problems.
- Greg
Previously owned...
Senile Member
Maybe BRP will introduce that custom made piece of foam for the fuse box and call it the "fuse pillow" and charge $29.95 for it.
Silver SM5 PE# 1274, Hindle Exhaust, Touring Windshield, Caliper Trim, B.E.S.T. 3 Year Ext, Nuvi 255 GPS, Fog Lights, Sport Rack, Back Rest, 12V Outlet, Talon 3300p Alarm, NMN Mud Flap and TipZ LEDs, SpyderLovers Emblems, Kuryakyn Widow Pegs and Axel Trim, Luimoto seat skin, Evo Air Filter and O2 Mod, Cranker Tank Bag, Blue Sea fuse block, MAD/AMS/MBG, Oddyssey battery, IPS.
Service Bulletin Applied: Gen II parking brake, 2nd SW patch, evap can/hose update, Gen II DPS
Bone Crusher
It is funny how everybody suggests putting foam under the top of the fuse box lid to put some pressure on the relays. My 2008 SE5 manufactured in July 2008 (as per the VIN sticker on the swing arm) came with foam already installed in the fuse box lid. Could it be that BRP was aware of that suggestion and incorporated it into the build of the bikes they built aft say July of 2008 ?
Just wondering but what was the date of manufacture for all those that had the loose relays and added foam to the fuse box lid ?
HAPPY 2008 SE5 OWNER 1" BRP Riser, NMN 3" risers, NMN Triple Play & Tail Light, Kewlmetal Mirror Extensions, Evoluzione Powerbus, BRP 23" Touring Windshield on CHAD Bracket, Ride-On in tires, J&M Integrator, Gerbings Dual Zone Temp Controller & Heated Gloves, 2 Dash Mounted 12V outlets, Kewlmetal Highway Brackets & Kuryakyn pegs, Trunk Spring Mod, Vista Cruise Throttle Lock, Kuyrakyn L.E.D. Battery Guage
I picked my Spyder up 4-15-08, it has foam in the cover for the fuse block, but the foam must be there for sound deadening, it doesn't reach the relays or fuses.
john
I check the relays every 300 miles when I check the oil level and mine have been tight. There already is a piece of foam in the top of the fuse box lid which is apparently just for the purpose of keeping the relays in place. Are you putting a thicker piece in and still able to get the lid to latch?
Mine has the foam inside the lid, as well. I took delivery of my Spyder 9/27/08. You can see the impressions in the foam of the relays. And, as I said; when I removed the fuse box lid, the main relay was unseated a little. The extra foam that I added, now keeps them seated firmly.
- Greg
Previously owned...
Can someone post a pic of their fuse box...I've never looked for it before to take a peek and see what surprises I'll find in mine! thanks...
Bone Crusher
Don't have a pic but its on the oposite side of the radiator fill bottle.
Happy SE5 Owner!!!
I would also get the numbers off of all the relays and buy one more of each.
I believe with the numbers you could try auto nation and or NAPA to carry around some spares just in case.
Northramp
Yellinacha
Very Helpful Member
Forum
F3 Shop Talk
