Results 1 to 4 of 4
    Feb 2015
    Kansas
    Default Floorboard Rubber Pads
    I was recently on a trip on my 2012 RTL and had the rubber on the left floorboard come off. When I got home I looked on internet and found out the you couldn't buy just the rubber pad, you have to buy the whole floorboard at $200-$400. Being cheap as Ia am I thought there has got to be another solution. So I removed the base plate yhat the rubber pads mount to, the bolts on the bottom of floorboards, and the rubber grommets . This left just the floorboard base which bolts to bracket . I then went to Home Depot and bought a rubber floor mat (like you use outside your front door) cut to the shape on the floorboard and glued it on. Problem solved for about $10. As I said I am cheap.
    Active Member HIspyder's Avatar
    Sep 2014
    Kauai (The Garden Isle), Hawaii - USA
    If you're looking for stock parts, BRP's parts site shows a break-down of the rubber components which are available separately.
    https://www.brp.ca/spyder/shop/for-s...ts-iframe.html
    Just another crappy day in Paradise....Aloha!
    Jul 2015
    Dorr, michigan
    Quote Originally Posted by HIspyder View Post
    only $50.51 per side at http://www.powersportswarehouse.com/...SAAEgLzr_D_BwE
    2020 RT Limited , Petrol Blue
    Good fix. You must be related to Blue Knight.
