A Arm Bushings
It seems that I need new A Arm bushings on my 2013 RTL. The dealer wants over $450 to replace them, I look at it and wonder if I could do this one.
I am sure some of you have done it, any advice, positive or negative are welcomed. Are there any videos out there that you know of for this?
Joe
as long as you have access to a press it should be a piece of cake. I would also replace the ball joints while you have it apart, whether they are bad or not. bushings at cheap cycle parts are shown at $13.97 each, ball joints at $45.97 each.
Why would he need access to a press exactly?
tight fit
hey freddy , I am not looking at the area where this bushing fits , but I have replaced A frame bushings before ( in a 1970 ford car ) and they are a super "TIGHT " fit to put back into the housing of the A arm assembly , when you pull the links apart ( when the bushings are bad ) they fall right out , and the new ones almost seem like they will be 1 1/2 sizes to big , which needs to be pressed in ---- or ---- using a super size " c " clamp heavy duty c- clamp will press one in if you are careful and have extra hands to help hold the A arm and the -c- clamp while some one with a cheater bar spins the clamp to press in the bushing ! most likely a bigger c clamp than this one , a deep throated c- clamp
All of this, thus far is very helpful. I was not planning on the press, so thanks, also the idea of a super clamp is interesting. I figure if nothing else, there are small shops around, if I take the arms off, bring it to them they will press them in for a minimal charge.
Thanks for the pricing, that is sure a lot less than $450.00.
Has anyone done it as a DIY? Other the aforementioned challenges, is difficult is it to remove and reinstall the arms. I did it on a 1963 Ford Falcon about 100 years ago when I was young and stupid.
Joe
I think our friend may nearly be able to do the job with little more than his bare hands, basic tools.and care.
Search should give results.
Yes, thanks, I tried to search the topic and could find nothing.
Though I visit here abou every day, and I glean much from the conversations, I find the search function totally uncooperative.
Joe
2013? How many miles? Seems strange you've worn out the bushings in 4 years.
Current: "Scarlett", 2017 Can Am F3-T, SE6, Intense Red Pearl.
BRP heated grips, DIY brake light strip and turn signal strips, Chrome/LED brake light tag frame, SpyderPops bumpskid, Baja Ron swaybar and billet links, Lamonster Third Peg, BRP Adjustable Passenger Backrest, SpyderPops Missing Belt Guard, ShowChrome oversize brake pedal, TricLED foglights.
Previous: "Synthia", 2014 Can Am Spyder RT, SM6, Pearl White.
There are 28K miles on the byke right now.
I thought the same, but when I took it in for an alignment, they said that it would be a waste of money because of the slop in the bushings on the right side. I said show me. The right seemed tight, the left is loose, not terrible, but it has movement.
Joe
Joe
I've found Youtube to be far more likely to have DIY videos than this site.
How was it shown to you?
I have a 2014 RT Ltd with 39,000 miles. I would to assess my front suspension bushings before I trailer it to Arizona in February. I have put the bike up on my 4 post lift and then used a floor jack under the outer strut of the frame to raise the front wheel off of the platform. I could not find any sloop in bushing with this approach.
Just curious if this was the set up the dealer (Johnny K's?) used when he showed you your problem?
2014 RT Ltd Silver Platinum Satin, Ultimate Seat, rider and passenger backrests, Vented Windshield, Adjustable Side Wind Deflectors, Chrome Tri Axis Handlebars with GPS Support, Trailer Hitch Kit, RT-622 Trailer Silver Platinum Satin, Stebil Air Horn, BajaRon's Sway Bar, Spyderpops Bumpskid bike and Trailer, R/T grills, SpyderSisters Front Trunk Pockets, SpyderSisters Sunshade, Spyderflaps Mud Flap, many TricLED lights
A Arm Bushings
The A arm bushings are easy to replace. Jack up the Spider and block it.Remove the bolts from one A arm at a time. Tip it out, pull the steel spacer in the center bushing and pull out the bushing on each side. To replace ball joints, you need a press or ball joint c clamp.
