Page 2 of 2 FirstFirst 12
Results 26 to 46 of 46
  1. #26
    Jun 2011
    Harrisburg, PA
    Default I have a set of "like new" full size Seal floor boards for sale
    I was about to post in For Sale but I saw this thread... Asking $299.
    Seal full-size floor boards for Spyder RT (and RT-S and RT-Ltd) without factory boards.
    Darn near perfect condition. Mount in about 15 minutes and the hardware is included.
    They came off of my 2011 and my "new" 2014 has factory boards.
    Shipping at actual cost or may be picked up or I'll drive up to 100mi from Harrisburg, PA to meet you half way.
    Ryde Comfortable !!!
  2. #27
    Apr 2018
    Pulaski, VA
    sent you a pm
  3. #28
    houston,texas
    Default floorboards
    I had Seal Floorboards on my 2015 F3S and they were great and easy to install !
  4. #29
    Aug 2010
    Newberg, Or.
    Quote Originally Posted by FrankPa View Post
    Sounds like a great deal, Frank. Best of luck.
    Ride in comfort,
    John
  5. #30
    Apr 2018
    Pulaski, VA
    They will be heading my way soon, and I am greatly looking forward to installing them
    Quote Originally Posted by sealfloorboards View Post
    Ride in comfort,
    John
  6. #31
    Jul 2018
    Newfoundland
    Default Seal Floorboards
    Got a set of Seal Floorboards(ordered on July 26 received on August 3)not to bad for living in Newfoundland.You mite wonder where is Newfoundland?The answer is it's half way to Heaven.Anyway installed them,used them ,much better than the pegs that came with my 2012 RT Limited.Makes it a lot easier and safer for my wife to jump on the back.Would commend for comfort,safety and style.Good people to deal with.
    2012 RT , Pearl
  7. #32
    Aug 2010
    Newberg, Or.
    Hey folks, just because you have the small BRP Factory Floorboards doesn't mean you can't have the full Seal RT SE5's on your Spyder. I have a set that fits right on top. When ordering, just click yes or no to "Have BRP floorboards". Super easy to install. Call or email me directly and I'll drop the $45 shipping charge (US only). You too can stretch out and,
    Ride in comfort,
    John
  8. #33
    Active Member solidgranite's Avatar
    Aug 2016
    North Carolina
    I also have a 2012 RT SE5...and wanted floor boards to replace the very uncomfortable foot pegs. I got a pair of floor boards from canamspyderaccessories.com in Canada. They offer two sizes, and I went with the small ones. Took under 10 minutes to install them.. Now my feet are resting in a flat position when I ride...much more comfortable, especially on long rides. I paid around $100 plus shipping. I looked at the "others", but they wanted several hundred for a pair, and I wasn't willing to pay that much. These do the trick perfectly, are strong, rust-proof, and stable. I'm very pleased with 'em.
  9. #34
    Dec 2016
    Port Richey, FL
    Thanks for the tip. I'll check them out. Can you stand on them without them flexing? I just can't see paying $400 - $900 for a pair of floorboards.
  10. #35
    Very Active Member Y Rider's Avatar
    Oct 2010
    Springfield, MO
    I am using Seal Floorboard Pups on my 2011 RTL. I put them on in September of 2011 and they still look great. They are very comfortable and have been very happy with them. This is the same Spyder used in their advertising.
    MODS: Elka Shocks, ESI RT HMT Brake Light, ESI RT Brightsides, ESI Fender TIPS, ESI RIPS, ESI RT Day Runners, Grip Puppies
    AmerSeal Sealant, KewlMetal Kewlock, Scorpio I900 Security System, Stebel Nautilus air horn, KewlMetal Highway Brackets & ISO Wings
    Corbin seat, trunkrest & driver backrest, Capt.Jim's Belt Tensioner, SpyderPops LaBlock, Cat Shields, Bumpskid & Belt Guard
    Seal PUP Floorboards, BRP chrome, Ron's Anti-Sway Bar, Lamonster LED Head/Fog Lights & BRP Air Scoops
    2011 RTL , White
  11. #36
    Aug 2016
    North Carolina
    "Thanks for the tip. I'll check them out. Can you stand on them without them flexing? I just can't see paying $400 - $900 for a pair of floorboards."
    Yes, standing on them is no problem. They don't flex at all under my weight (175 lbs), and the small size ones are plenty big enough for my riding boots. You can hit the brake pedal easily because the right side one is sculpted to leave plenty of room around the brake. They have a textured surface so my feet don't slip around on them. They're very easy to install. Reove the rubber part of the foot pegs, and then bolt these on. The hardware (bolts and nuts) comes with the floorboards. I'm very pleased with them, and my feet are much happier! :-)
  12. #37
    Jun 2019
    jstreet
    Default Floor boards
    Quote Originally Posted by donsspyder View Post
    I have a set of seal floor boards of a 2012 RTS, that I will sell for 200 dollars. Just like new. I traded it for a 2017 RTL. They have big factory boards on them. Call me at 1-607-432-3069. If you have any questions, call me. If you want a picture of it, my son will send it to you.
    Just started with Spyderlovers...
    Have 2012 RT SE5, Floor boards still available?
    Al
    2012 RTS SE5 , Spider Web Brake pedal Orbital blue
  13. #38
    Durham,Maine
    It's a real shot in the dark that there still around! When your poking around in this site, there is a lot of good info on here, but in this case if you look at the top you will see when the post was started! It's back there a while ago but good luck, some one may pop up and want to sell a set!!
    2012 RTL , Pearl
  14. #39
    Quote Originally Posted by CADRE View Post
    Al
    Well Seal Floorboards has stopped selling them ….. They can easily be made from 1/4 in. diamond plate aluminum …. that's what I did …. you take off the OEM peg covers and attach using those oem holes …. make the boards long enough to reach the bolt that attaches the lower side panel ( metal ) and make a bracket from steel flat stock …..cost about $20.00 ……...good luck … Mike
  15. #40
    Jun 2019
    jstreet
    I am special... my seal boards arrived with chrome edge coming off at the bends... The rubber foot mat was not cut evenly in various places... They work great.. Had I known of the lack in quality I would not have bought them... Many other options.......
  16. #41
    Jun 2019
    jstreet
    I must have received the damaged set.... Am looking to make my own or buy from SPYDER ACCESSORIES.... The idea of having low quality workmanship under my feet. Makes me wonder what’s under the rubber foot mat... Crazy thoughts maybe... At $500.00 not worth the price from Seal.... I do know the bolts after one week already started to rust....
  17. #42
    Active Member Eviltwin's Avatar
    Oct 2017
    Portsmouth VA
    Here is my version of home made. Rear mounts on a stainless carriage bolt that has about a 1" square hard rubber sheath. Stainless bolts throughout.
    2019 BMW C650GT, 2010 Spyder RT-S, 2009 BMW R1200RT,(sold) 2009 Honda Silverwing (Sold), 2009 Kawasaki 500 Vulcan (Sold)
    2010 RT SE5 , Black
  18. #43
    Aug 2020
    wisconsin
    anyone still sell seal boards floor boards looking to get some. not liking what I see and the price is horrible might have to make my own.
  19. #44
    PA
    I believe the company was closed 2.5 years ago. He had someone to take over but then it fell through. I purchased his removable rack. It was the last he had. Watch the selling forum. I saw a couple pop up over the years. There was an pink set last fall I think. Might look back. Not sure of the model though.
  20. #45
    Dec 2019
    CA
    If you're going to attend Spyders at Red Rock next week, i will be there and install your Seal Floorboards for FREE.
    If you are going and know you want a set, Let me know and I will put your name on a set. I usually sell out so don't miss this deal (plus there are no freight charges).
    Ride in comfort,
    John
    Do you have a link for Seal floorboards?
    Last edited by Peter Aawen; 04-04-2024 at 08:47 PM. Reason: Removed Post title - they mess with Searching! ;-)
  21. #46
    Mar 2017
    Salisbury,NC
    Quote Originally Posted by Sabre85 View Post
    they have closed down. view #44. can only find used or someone selling these
Tags for this Thread
