Results 1 to 10 of 10
    Phoenix
    Default Two RTS's in an 8.5 x 16 enclosed trailer
    Have you trailered 2 rts's in a 8.5' x 16' enclosed trailer?
    curious..not any other model
    2 RTS's
    Default TOO SMALL TRAILER
    Quote Originally Posted by marty1096 View Post
    2 RTS's
    The RT's are about 9 /12 ft long .... it can be done ...but you will have to put the tails alongside each other .... not an easy task .... pretty easy the scratch something .....Mike
    Active Member Hecam17's Avatar
    Sep 2011
    Acworth, GA
    Default Sam's Vlog
    We ride with a couple in Atlanta Spyder Riders, Sam & Susan. Sam is also a vlogger and he happened to do one episode on towing an RT and a big 2 wheeler in an enclosed 7x14 trailer.
    I know you asked about towing 2 Spyders, watch how he moves the Spyder around once on the trailer, that's the answer you are after. Like Mike said above drive on one, back one on and move the rear wheels with Sam's tip. He's a good guy and his vlog is entertaining as well.
    Good luck
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Hecam17 View Post
    We ride with a couple in Atlanta Spyder Riders, Sam & Susan. Sam is also a vlogger and he happened to do one episode on towing an RT and a big 2 wheeler in an enclosed 7x14 trailer. I know you asked about towing 2 Spyders, watch how he moves the Spyder around once on the trailer, that's the answer you are after. Like Mike said above drive on one, back one on and move the rear wheels with Sam's tip. He's a good guy and his vlog is entertaining as well.
    Good luck
    It seems he just grabs the passenger grab rails and drags it? I'm not sure I'd want to do that too many times.
    2014 RTL Platinum
    Default MOVING REAR OF .... RT
    " IF " you place two pieces of sheet metal on top of each other ( say 12 X12 & a 12 X 20 ... larger one on bottom ) you can EASILY slide the RT sideways ..... I wouldn't try doing it on bare wood etc .... the passenger Grab handles are strong ... BUT NOT THAT STRONG !!!! ..... Mike
    Mar 2016
    Baytown, TX
    16ft won't work you need at least an 18ft trailer. I wanted to use a smaller/cheaper trailer but due to the length of the bikes I bought a 20ft trailer since it was the same price of an 18ft. You can put them in nose to but without all that finagling and sliding them around. I've only used it once in 4 months but it worked great. Xtra room for carrying things you find on the road trip.
    2015 RT , Black
    United States
    We had to go to an 18' (with the bull nose it actually is 19'6") when we got the second Spyder. The 16' was just too short. Also, make sure what you are towing with can handle it. We use a F150 4x4 with the towing package and I still had to beef up the rear suspension so that our headlights weren't "hunting squirrels". Good luck!
    Active Member Michaelscs's Avatar
    Sep 2015
    Cold Spring, MN
    I think you guys missed that the OP asked about a 8.5' x 16' trailer. I think the 8.5' trailer would allow him to fit 2 RT's in a 16' trailer. Tail beside Tail
    2020 RT Limited
    2020 RT Limited , Petrol Blue
    Default MISSED MEANINGS
    Quote Originally Posted by Michaelscs View Post
    I didn't miss it ....and neither did you ..... Mike
    Member smoof's Avatar
    Aug 2017
    Kansas City MO
    we did it this weekend on a 16ft trailer with sides (I believe it might have been 6.5 wide). the trailer sides are inside the wheels. we put the first one on and hugged one of the sides with the front tires and put a floor jack under it and slide the rear tire to the opposite side as far we could and then did the same with the second RT and strapped them down. it was tight but we went about 170 miles and back (340 miles total) with no problems. they were loaded nose to tail.
