Page 1 of 2 12 LastLast
Results 1 to 25 of 42
    Apr 2012
    Arizona
    Default How Full is Full?
    I've noticed when I fill up my RT at the gas station, I stop when the gas nozzle clicks and stop pumping. When I leave and look at the gas gauge it shows less than full (needle is under the "F"). Has anyone noticed that? Do you squeeze a little more in the tank after the gas nozzle clicks?
    Jun 2010
    Las Vegas
    The trick is to only insert the nozzle about 3/4". When it squirts through the vent give it one more shot.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jul 2014
    Mint Hill, NC
    Quote Originally Posted by SpyderAnn01 View Post
    Yup, right on! Had to do it today with 93 Harvey gas @ $3.20/gal, about $.40 more than normal. Station was flat out of low and mid grade so everyone was buying 93; wouldn't have used low/mid anyway.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Active Member ChrisW's Avatar
    Oct 2013
    Fernley, NV
    Fill to the plate inside the fill tube
    The Wife's 2014 RTS SE6
    New tires: Back, KUMHO ECSTA 225/50 R15 (24psi) @ 9,380 miles, Fronts, KUMHO SOLUS KH16 175/55 R15 (20 psi) @ 9,421 miles
    Aug 2008
    MA & NH
    Kind of a pain but I'm used to it.
    Active Member drhunt204's Avatar
    May 2016
    S.E. Missouri
    After the first stop on fueling I pull the gas hose about half way out and then pump in more until it clicks off again. Then I stop and put the gas cap back on the spyder.
    Registered Users classicvw's Avatar
    Aug 2017
    New Jersey
    I just stop when the pump clicks off. The fuel looks quite close to the bottom of the filler neck at that point, and also the owner's manual says don't stuff it.
    Even though the fuel level looks like it's right at the filler neck, the highest my fuel gauge will read is just below full.
    Sep 2015
    Parkesburg,Pa
    I agree with Ann,I do the same thing,get more miles before the next fill that way.
    Apr 2017
    North Central Florida
    So far I have found that procedure to be messy......since it is almost impossible to finesse that last shot with most pump nozzles......so I stop when it first shuts off, after removing the nozzle and LOOKING to see that the level is close to the bottom of the "cup".
    But yes, not inserting the nozzle end too far seems to be the key.
    P.S. Just because the gauge does not say FULL does not mean that it isn't.
    The gauges are notoriously inaccurate, especially on the older models.
    Aug 2017
    New Jersey
    Quote Originally Posted by Easy Rider View Post
    Excellent point!
    Default Look....
    You can seel the level in the tank on most models. The best is to fill till it bubbles back throught the breather slots. Here we have to hold back the elephant trunk added to the filling nozzel because of EPA but works. On models without the analog this will get that small wedge at the top of the bar digital guage....They used to make a gizmo to hold back that nozzel cover....
    ​2012 RS sm5
    Aug 2017
    New Jersey
    Those elephant nose add ons to the pump nozzle are no longer required. Many stations have taken them off or not replaced them when they wore out.
    Nov 2012
    North Las Vegas, NV
    Elephant trunk, we call them California condoms.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    I will add my .02 to the thread. This information usually accompanies gas mileage threads--as in fill the same each time.
    For whatever reason, the gas settles a bit after pump shut off. I fill until the gas reaches the metal ring. Let it settle for a couple seconds, and re-fill to the ring. Done.
    This method gets the two cylinder (and I have had four of them) to at least 150 miles before the light goes on. The three cylinder gets 210 or so before the light.
    WARNING, WARNING, WARNING--YOUR FILL LIGHT RESULTS MAY BE DIFFERENT.
    Active Member almosthere's Avatar
    Jan 2016
    Paw Paw, Michigan
    Default .
    If I'm filling close to "E" on my '15 RT-S I can only get about 5 gal in with the nozzle in half way. pulling it back to just barley in I can put another gal and a half in. Most I've put in is 6.58 gallons. that gets me about 230 miles.
    Aug 2012
    CO
    All filler nozzles are double walled tubes. There is a small pinhole on the end that when liquid gas reaches it, it causes a vacuum break in the handle that shuts off flow. When you're filling the tank, the gas sloshes about and the "waves" cause the pump to shut off early before the tank is truly full. Waiting a couple of seconds for the sloshing to stop and withdrawing the nozzle a bit let's you fill that final bit of gas. "Top off the tank" is exactly that... filling it that last bit.
    JLohPhotos
    2008 GS , Millennium Yellow
    Jan 2015
    southern WI
    OK, since when did the common sense of pumping gas become so complicated?
    2021 RT Limited
    2016 RTS , Pearl White
    May 2013
    Indiana
    My version of the "2-Stage" tank fill is this:
    1. Insert the fuel filler nozzle completely into the gas tank set it on auto fill, and wait till it shuts off.
    2. Reposition the fuel filler nozzle until it just sits in the gas tank opening. Set it on the first auto setting, and wait till it shuts off
    Put the gas cap back on and go on down the road.
    Mike
    2021 Marsala Red Metallic RT Limited
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Ditto to #18. Mike
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Sep 2016
    Parma, Idaho
    Default Gas
    One of the stations in this area offering the lowest price of gas, aside from Costco, is Maverik. $3.09 for premium. My wife is still visiting family in Hemet, California and they rather laugh at our complaining. Regular gas at $3.09 is rather inexpensive there. And I hear that Governor Jerry has assured residents in California of a rate hike in gas there in the near future.
    Greenville Tx
    Fill till it clicks off then pull the nozzle out a little and run it slow till it spits out the vent like Ann described. Once it does that, dont do it again because you may over fill it. You should see the level right to the bottom of that filler neck, If you dont do that and ride in a group, you may run out before you get to the destination. That happened to a lady riding with us to Spyderfest last April in the rain.
    2017 F3 Limited
    Greenville Tx
    Another good question is when to Refill. Dont wait till you get to the last bar or the low fuel light comes on. Once your gas level starts to make you think about it, pull over and fill up. It will give you a needed break anyways. No need to occupy your mind about your gas level. It will allow you to enjoy your ryde so much better and relax.
    2017 F3 Limited
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    Quote Originally Posted by Mazo EMS2 View Post
    X2
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Apr 2017
    Quote Originally Posted by asp125 View Post
    BUT.....there is a point past which you should NOT go.
    Having it too full is a bad thing.
    AND making most gas delivery nozzles run "slowly" is nearly impossible.
    This is being "Over-Thunked" to the point of making me nauseous!
