Results 1 to 12 of 12
    Active Member Spider-man's Avatar
    Mar 2017
    San Antonio
    Default Lots of wind on my new F3T. X-creen?
    I really get beat up at highway speeds on the F3 with the little curved standard windshield. Do I have to replace the windshield to remedy this or would an X-creen be sufficient? I'm about 6' tall.
    You're gonna need a bigger windshield...
    But this is the bike that you bought: it's not an RT!
    Never understood why they put those small windshields that do nothing on most of the F3's. I had an 08 GS and 09 RS--both came with "mini" windshields. Had to get creative in those days--found aftermarket and ended up with big as the RT's of today.
    The OEM's would have made nice helmet visors and not much else.
    Very Active Member ofdave's Avatar
    Jul 2017
    sarasota, fl
    I think the X-creen will be a big help.
    Have had them on a couple bikes and will be adding one to my F3.
    I prefer the bolt on version. It allows for better positioning adjustment in my opinion.
    There are two sizes-the "sport" and "touring". The touring is about 15 inches wide.
    Most people feel they need to be mounted so they are much higher than the windshield they attach to. Not true, a couple inches is all that's needed to move the air over your head. And the angle should pretty much match the angle of the stock windshield (not near vertical as many do) to get best results.
    They are adjustable with an allen wrench so you can fine tune it while out on a ride.
    They are on Ebay and Twisted Throttle has them also.
    2017 F3, SM6-basic black, plain and simple
    Apr 2012
    Northglenn Colorado
    Fortunately the Stock windshield is perfect for me on my 2017 F3T but I am only 5'4". I had the x-creen on my 2015 F3S with the Blueridge and it worked great. I liked the x-creen because it was adjustable and I did not like the huge after market windshields that were available for the F3S. I want to go riding not sailing. I had it on for 2 years and when I took it off there was not a single scratch or scuff mark (I used the clamps) on the Blueride. I think the X-creen would be your cheapest option.
    Jun 2010
    Las Vegas
    I don't mind the size of the stock windshield on the F3T but I hate the curve at the top, it really distorts things. For now while it is hot I'll stick with it but I'll likely look fir other options this winter
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    You'll need BOTH.
    Running a 28" F4 shied and the X-Screen.... works great.
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Default Helps...!!
    20161003_122000_resized_1.jpg this is on my RS but helps a lot on the freeways....
    ​2012 RS sm5
    May 2013
    Apex, N.C.
    I have owned my F3T since late April. The stock screen seems to work for me, but I actually just ordered a larger one today for the cooler temps that come with winter.
    Active Member KJWEB's Avatar
    Jun 2015
    Midland, TX
    Quote Originally Posted by SpyderAnn01 View Post
    Can you say, "F4 Customs"? By far the best option for aftermarket windshield for the F3T.
    www.sasspyders.com
    2016 F3T
    2015 Freedom Trailer
    Sypderpops BumpSkid Plate
    Lamonster ISP Key Cover
    Lamonster F3 Bar Clamp and Power Port
    Lamonster RIP floorboards and frame caps
    Lamonster Chevron Highway Pegs
    BajaRon Swaybar & Heim Links
    F4 Custom 21" tinted windshield
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    Cat Delete Performance Pipe
    F3T Top Case
    PPA Black Widow Wheels
    Custom Frunk Wrap
    SpyderLovers Sponsor F4 Customs's Avatar
    Nov 2012
    Twinsburg, Ohio
    Default F4 Customs Windshield for the F3T
    F4 Customs, Inc.
    "The Motorcycle Windshield Folks"
    941-347-7496
    sales@f4customs.com
    <a href='http://www.spyderlovers.com/adserver/www/delivery/ck.php?zoneid=22' target='_blank'><img src='http://www.spyderlovers.com/adserver/www/delivery/avw.php?zoneid=22&cb=567846784' border='0' alt='' /></a>
    Active Member LateLifeCrisis's Avatar
    Oct 2016
    Maryland
    Quote Originally Posted by Spider-man View Post
    To eliminate "Bobble Head Syndrome," I went with the X-Creen and am very satisfied with it. I like being able to adjust the angle for more/less ventilation and although it's only been installed since spring, the adjustability enables me to catch more of a breeze on those hot days, yet keep the wind from rattling my pea brain around! You have to "play" with it to find the angles that work best for you - I've found the "sweet spot" and the air just seems to flow over my helmet, eliminating the turbulence as well as the wind noise. The clamp on version is the one I purchased - - I wanted to make sure it worked before committing to a bolt on installation and it's very secure and stable. I'm 5'4" and I can still look over it - - my Honey has the RT and I just don't like looking thru that tall windshield. I have a 2016 F3 and bought the "touring" style X-creen.
    He's on his RT She's on her F3
    And the Keys to a Happy Marriage: Separate
    Bathrooms, Individual Remote TV Clickers, and
    His and Her Spyders.
    "If there are no dogs in heaven, then when I die,
    I want to go where they went." ~ ~ Will Rogers
    "Never in the field of human conflict was so much owed by so many to so few."
    ~ ~ Winston Churchill in his tribute to the RAF.
    "I'd like to know why well-educated idiots keep apologizing for lazy and complaining
    people who think the world owes them a living." ~ ~ John Wayne
    GOS 3799
