Results 1 to 25 of 33
Thread: Helmet Holders
    Active Member Border Rider's Avatar
    Aug 2015
    Derby Line Vermont
    Default Helmet Holders
    I saw a post a while back on SL where a guy made a helmet holder for his Spyder out of a piece of metal. Nothing to do today so I decided to make my own.
    I used a piece of white vinyl porch railing I had laying around, so it won't scratch the paint; a Dremmel tool; utility knife; tin snips; and a heat gun are all that I used.
    They work great and I just turn them over and then store in place under the seat.
    Last edited by Peter Aawen; 09-06-2023 at 07:44 PM. Reason: Fixed attach display ;-)
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Border Rider View Post
    I saw a post awhile back on SL where a guy made a helmet holder for his spyder out of a piece of metal. Nothing to do today so I
    decided to make my own. used a piece of white vinyl porch railing I had laying around so it won't scratch the paint. A Dremel tool, utility knife. tin snips and a heat gun is what I used. They work great and I just turn them over and the store in place under the seat.
    Innovative solution to a common problem. Nice!
    2014 RTL Platinum
    Active Member Cleg's Avatar
    Apr 2012
    Queensbury, NY
    Default Oh so easy...
    For a mere few dollars, one could buy a plastic coated stainless sreel key ring with a barrel nut, run it through the D Ring, and use the hanger under the seat. Storage in the glove box is easy, hooking is easy and fear of theft is non existent! To the design ingenuity in post 1!
    Northern Kalifornia
    I do believe you're on to something there.
    Very Active Member robhowen's Avatar
    Apr 2015
    Tucson, AZ USA
    Default Good job, love to see DIY
    Great job.
    Rob
    2015 RT-Ltd SE6 and F3S SE6, both with a number of commercial add-ons plus my own tweaks.
    Very Active Member HayRog's Avatar
    May 2013
    Sacrament0, CA
    Jul 2010
    Las Vegas, NV
    Love it!
    For those not as talented; go to pet smart. Buy a small choke chain. Pass thru D ring, hook on helmet holder. Close seat. Done. 😃
    Last edited by Peter Aawen; 09-06-2023 at 07:40 PM. Reason: Moved Post title... ;-)
    Joe Meyer
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    Why not just hook the helmet strap over the hook under the seat?
    2010 RTSM5
    2010 RTSM5 , stock Stock Silver
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    It appears that in most cases, or at least mine, that the helmet strap is not long enough to reach the hook and then close the seat. I choose to put my helmets in the frunk and right side saddlebag to prevent any tampering and not have to remove my communications every time to prevent stealing.
    Active Member george123's Avatar
    May 2017
    San Antonio, Rogers Ranch
    Quote Originally Posted by Cleg View Post
    Pictures please.
    Active Member CrashDavis's Avatar
    Jun 2017
    Niceville, FL
    Quote Originally Posted by Zip View Post
    Not only is my strap not long enough, but the d-rings aren't big enough to fit over the hook. I invested in the Lidlocks, but if I had thought of it I probably would have done the chock chain thing.
    2017 RT Limited
    Sep 2016
    LI NY
    Quote Originally Posted by CrashDavis View Post
    That,s too bad , I have a half, 3/4, and modular and they all work. FYI choke chain is soft and easy to cut.
    2010 RTSM5
    Oct 2014
    Ohio
    How does it lock ???? Probably a stupid question, I am probably missing something !!!
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by biker01red View Post
    If you don't know it is not stupid. Just pass one end of the chain thru your helmet "D" rings. Pass the small end of the chain thru the big end. Put the big end over the helmets hooks under the seat. Close the seat and your helmet is locked on.
    If I put my chin strap just barely thru the "D" rings it is long enough to slide over the hooks and keeps the helmet snug against the seat also,but I think I am going to look closer at the choke chain solution. Nice piece of work there Border Rider.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Oct 2014
    Ohio
    Thank you very much !!!!!
    Dec 2017
    north central Texas
    very nice work, I work in a plastic supply and we do fabrication you gave me ideas for using polycarbonate
    Jun 2017
    Crossville TN
    We have the Nolan N40s, that has the microclick chin straps there is not enough play in them to use the hooks under the seats. I like some of these ideas but am wondering about security (theft) though
    Dave
    INDIANA, USA
    I can put 1 Helmet in my frunk But then I have NO Frunk Storage. I have ALWAYS wondered why BRP Did not offer a larger rear trunk. Little Blue
    Last edited by Peter Aawen; 09-06-2023 at 07:39 PM. Reason: Moved Post title... ;-)
    Durham,Maine
    Good idea, well done!!!
    2012 RTL , Pearl
    Jun 2017
    Austell, GA
    I was disappointed when I discovered that my new F3's Frunk was not large enough to hold my Arai full coverage helmet. My solution was to buy an inexpensive helmet lock and install it on the rear tubular frame. This may not be a panacea for everyone, and I have heard all the stories about the perils of using such a device: they are not really secure; a bo hunk sized screwdriver can break one; cutting the strap and making off with the helmet is easy; and sending your expensive helmet back for repairs is a cheap fix. Still, for most instances when I want to walk away from the machine and don't want to carry my lid with me, it works fine.
    There comes a time in life when you really want to stay in the wind, but single-track vehicles are no longer a practical or safe solution. The Can AM Spyder is a wonderful answer to a difficult situation.
    Dec 2017
    Ontario
    Hi, here's what you're looking for:
    Last edited by Peter Aawen; 09-06-2023 at 07:38 PM. Reason: Fixed quote display & removed multitudes of extraneous CMD lines?! :-/ ;-)
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    Uhh...I see no helmet hook tabs under the seat on the ST-S...
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    Jul 2018
    Fountain Hills,AZ
    Hey you wouldn't have a pattern would you? I could print it out and make my own..Carpenter with a lot of tools..
    Active Member amusher's Avatar
    Apr 2015
    11 Mile/Spinney CO
    I have modular helmets. I bought 2 - 18" long pieces of small cable and the ferrules and put loops in the ends. We hang our helmets on the mirrors so I just loop a cable thru the chin bar and thru the slot in the mirror and put a small travel lock on it..
    Jul 2018
    Fountain Hills,AZ
    Quote Originally Posted by amusher View Post
    Yep Have that just wanted to tinker..
