Results 1 to 25 of 35
    Mar 2017
    Star, Idaho
    Default My Spyder let me down today
    Went to post office and when I came out the parking brake would not release, I have almost 4000 miles and it has been flawless till today. I did do something different but I don't think it caused it but now sure, I turned key and before pressing the eco button I released brake (Don't ask me why), I noticed it didn't release it, I then started it and it was stuck, every time I turned off it would beep at me like I didn't press the brake before turning off. I turned back on and it would be blinking, press brake button and it would turn solid and keep doing this over and over. Dealer had me press brake by foot and try but nothing, my dealer drove over and took brake off and took my bike to dealership. Bummed bigtime, I now know how to release it but have to wait to see what is stuck, maybe relay?
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Ramg66 View Post
    I do that most of the time and it hasn't caused any problems for either of my 2014RTLs (knock on wood). I can't imagine the sequence of releasing the parking brake is likely to create a problem with the electronics, but I could be wrong.
    BTW, in case it happens to me, how do you release the parking brake when the switch won't do it?
    2014 RTL Platinum
    Mar 2017
    Star, Idaho
    Right side of the rear wheel, just undo the bolt with the brake cable and take off. You can ride it like this but have to put up with annoying beeps for a few seconds when staring and turning off.
    Mar 2017
    Myrtle Beach, South Carolina
    Default Brake release
    Try, disconnecting the battery and hooking it back up. Might have to reset the logic in the computer.
    Mar 2017
    Star, Idaho
    I was going to do that, dealer told me not to. It made sense to me because the brake is electronic, but they came and picked it up and its at the dealership now. I was pretty impressed they came and picked it up though.
    Default Bummer...😠
    But Wow..!! Great dealer..could suggest but now that they have it let us know what they find...
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    Default Me too
    I have had this happen several times now. I just turn the key off let it beep after about min or so it will stop I then start the bike and it has so far worked the brake disengages weird I know. I think it is in the switch. please let us know what the dealer says.
    Mar 2017
    Star, Idaho
    I wish it would have worked for me today, I will definitely let everyone know what they find.
    May 2013
    Sacrament0, CA
    I'll be interested to see what you and the dealership find out.
    This happened to me while on the road in Idaho a couple of months back. Only happened the once but unsettling non the less.
    I'll add you to the list of 12 it's happened to so far.
    Who's your dealer ?
    Mar 2017
    Star, Idaho
    Birds of Prey Motorsports in Caldwell ID, I was reading the manual (which I should put back in the Spyder) and I saw a part that said to check fuse No. 1.
    Mar 2017
    Star, Idaho
    Its happened to 12 people? WOW!! How long was your Spyder in the shop? I have my Idaho Star Trike training this Friday and Saturday I guess break downs are never good timing
    May 2013
    Sacrament0, CA
    Never really got to my local shop yet. PM'd you --
    Hope the training went well :-)
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    excellent service!
    Mar 2017
    Star, Idaho
    My training is next Friday and Saturday, I figured today was Saturday so I said "THIS Friday.......". The dealership said they might even loan me a demo for the training.
    May 2013
    Sacrament0, CA
    That dealership's a keeper
    GOS member (Girls On Spyders) Spyder_Cowgirl's Avatar
    Bowie, Texas
    Default Fuse
    If it were the fuse, then your windshield would not move up and down .... that is an easy way to check the fuse when the parking brake won't release. I had a switch go bad on my 2012 RT, dealer replaced the switch and never had a problem after that.
    All the best .... Ann
    __________________________________________________ _
    2016 RT Limited -- "Jubilee" (as in Cherries)
    Guardian Bell (gift from spyderowboy)
    ISCI Dual Flag Mount – Tall Poles
    Lamonster Bottle Holder and Spyder Cuff
    Spyderpops Missing Belt Guard
    Spyderpops Bumpskid
    Spyderpops Rear Run / Brake / Turn LEDs
    Spyderpops Mirror LEDs
    Custom Dynamics HMT Brake
    Spyderpops Keep Out The Trash (KOTT) Grills
    Don't Eat Mud / mudflap
    __________________________________________________ __
    Central Texas
    I have a 2014 RTL and I've one time where the "parking brake" would not disengage.
    The problem was that my brake fluid was low enough to trigger the nanny to keep the brake locked.
    How low was my brake fluid? I put a tablespoon if brake fluid in the reservoir that is under the seat and problem went away.
    Aug 2013
    Northern California
    That is what happened to out 2013 RTL. Just topped off the brake fluid and back on the road with no issues.
    washington state
    This is a good conversations, and will help everyone now and in the future. Thank you and enjoy the first BER month.
    RT-S PE#0801 timeless's Avatar
    May 2010
    Punta Gorda, Florida
    Default I had a similar experience
    and discovered the rear cable pivot had stuck in the brake applied position. It was stuck from dirt & grime, a little WD40 and hand movement got it working again.
    I now pay more attention to cleaning & lubing that area.
    Mar 2017
    Star, Idaho
    I talked to the dealer yesterday, didn't have time to post. They tell me the motor that engages the brake and releases it went out. They have ordered one and hope to have my Spyder to me in time for my Trike training. Thanks everyone for all the good advice. Ride ON!!
    Invalid Emails
    Apr 2017
    AZ
    This is a perfect example of how over-engineered this trike is. A simple manual cable with a switch would be a better solution. A 'park' lock position in the transmission would be more elegant as well. This motor adds cost, weight and complexity to a very simple purpose. You would think these trikes were engineered by old, British designers.
    May 2013
    Sacrament0, CA
    Quote Originally Posted by RinconRyder View Post
    Well said !
    Even though I'm British
    Aug 2013
    Northern California
    vcm_s_kf_repr_882x588.jpgAs near as I can tell, none of the designers are British. Most of them are Canadian and all of the other countries of origin are marked with the appopriate country flag. The guy in the middle is the guy who thunk up the Spyder in the first place!
    Dec 2015
    Oakley Utah
    You mean the ones that brought us the WWII Spitfire, the Rolls Royce Phaeton, etc, etc?
    I don't agree with you, and it's not just because I'm British. But, you are entitled to your opinion, as ill-considered as it might be.
    2014 RTL Platinum
