Results 1 to 19 of 19
    Active Member SteveandBelinda's Avatar
    Jun 2016
    Canton, MI
    Default Removing Pine Tree Sap
    Anyone know what may be safe to use on a BRP bike cover, to remove pine tree sap?
    2014 Can Am Spyder RT Limited - Pearl White
    2010 Can Am Spyder RT - Full Moon
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi SteveandBelinda,
    Re: remove pine tree sap?
    I had a pine tree next to my driveway when I bought my current house. I had the tree removed after dealing with this for too many years.
    I do not have a better answer,
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Active Member HankD's Avatar
    Jul 2017
    Huntsville Alabama
    Quote Originally Posted by SteveandBelinda View Post
    Try a product called "Goo Gone". It works on a heck of a lot of sticky residues, but I don't know if it is compatible with your cover, it could damage or remove color from it. It's available at a lot of places, Walmart, etc.
    Just Google Goo Gone...
    Feb 2012
    Spring City,Utah
    There are laundromats that have machines that will take a sleeping bag. They will be big enough for your cover and a mild laundry soap will take out the tree sap. Woolite, Arm and Hammer, something like that. If you have the time and the energy you can hand scrub it with those same soaps.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Very Active Member Larry rt's Avatar
    Jul 2013
    Vestaburg Michigan
    Dab the alcohol over the sap until the sapcomes off. Add a little mild dish soap to another corner of the cloth dampened with water. Wipe the fabric to wash away any remaining residue. Rinse the white cloth, then wipe the previously sappy area once again.
    How to Get Pine Tree Sap Out of Fabric | Home Guides | SF Gate
    I've heard it said, that WD-40 will take it off of a bike.
    But I'm not sure what it would do with a cover...
    Put some of it on a rag, and perhaps try holding it against the sap (to soften it up...)
    Northern Kalifornia
    Pine tree sap is petroleum soluble and cedar sap is water soluble. Hope that helps.
    Jun 2016
    Canton, MI
    Not from home. Got this a couple weeks ago when parked at hotel.
    Quote Originally Posted by JerryB View Post
    Hi SteveandBelinda,
    Jerry Baumchen
    Aug 2012
    CO
    Default Be careful
    Petroleum based solvents might remove the sap, but also some waterproofing coatings and fabric protectants. Be sure to test on an inconspicuous section first and re-apply fabric protectant afterwards.
    JLohPhotos
    2008 GS , Millennium Yellow
    Jun 2010
    Las Vegas
    I sat in sap with my Gortex riding pants and didn't have any luck with goo gone. Eventually the sticky came off but I was left with a white spot on my black pants. I may try the alcohol remedy listed above.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Northern Kalifornia
    Yes, if it's pine sap by all means start with the least powerful petroleum product first. Try it on something other than the lid of your fronk. If you're like most of us that live in the pines there well be many samples of pine pitch everywhere. Experiment on something else first. I use regular gas and it works well for me. Example, if I dribble gas on the side of my spyder while fueling up, I just wipe it off. No harm done. Good luck.
    Active Member spyderfish's Avatar
    Jun 2014
    West Bloomfield, MI
    Default Solvents are dicey
    Steve and Belinda,
    I do believe there is any solvent thatwill dissolve the sap without harming or at least marking the cover.
    I have had some luck over the years with sticky stuff using a powder approach. Perhaps dry baking soda rubbed onto the sap spots, maybe it will attach to the sap and release it from the cover. Other possibilities could be talcum/baby powder, flour, confectioners sugar; any really fine, inert powder is worth trying, I do not think it will hurt the cover.
    Just an idea, not proven.
    Gerry
    Default maybe this
    Try putting an Ice Cube on it and scraping it with something not too sharp .... this has worked on a few other things like Gum ..... PS this won't stain ..... Mike
    Feb 2014
    TX
    Default Removing Sap
    First read this on a hot tub cover manufacturer's website. Use olive oil. I have tried it and it works almost instantly, at least on sap from Douglas Fir and Western Red Cedar.
    2014 RTL SE6 Pearl White, Mfg. date 1/28/2014
    BRP heated seat, BRP backrest, SpyderFlap, Tricled mirror turn signals, KOTT Grills, BRP adjustable side air vent, Bumpskid, Bajaron sway bar and heim links, Spyderpops belt guard, Tricled day lighters, Tricled fender LEDs, CD HMT running/brake LEDs
    Sep 2007
    Rome, WI and Mayfield, KY
    Default Sap removal
    Use hand sanitizer. It is alchohol but will sit on the sap longer than liquid alchohol. I keep a giant bottle in my shop to safely remove sap from the toys. Let it soak on the sap for a long time.
    Lucky
    2015 RTS SE6
    2008 Harley Ultra
    1999 BMW R1200C
    1986 Harley Electraglide
    Very Active Member Vader's Avatar
    Jul 2014
    Hudson Valley
    Default I second this...
    It works..
    Quote Originally Posted by Lucky View Post
    IT IS, WHAT IT IS...
    Jul 2015
    Dorr, michigan
    Good old WD-40 works great for me. Then a mild detergent to take out the residue.
    2020 RT Limited , Petrol Blue
    Northern Kalifornia
    Default Back in the day....
    My grandmother used Crisco to remove just about anything off of just about anything.
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    Bug and Tar remover.
