Results 1 to 4 of 4
    Aug 2015
    Northern California-Sierra Mountains
    Default Parking Brake Release
    Having problems releasing the parking brake on a 2015, F3S. I have read all the threads, but would like to know the OEM part number for the parking brake switch.
    ANY HELP APPRECIATED. WE
    Dec 2014
    Graham Tx
    My parking brake locked up on my 2017 F3L and the problem was caused by the
    back lock nut on the brake rod had backed off allowing the parking brake pawl
    to be pulled over center and jamming. I wound up totally removing the brake rod
    from the brake pawl and tapped the pawl backwards with a hammer releasing the
    over center jammed condition. In hindsight I could have probably just tapped the
    pawl with a hammer and accomplished the same thing. Readjusting the brake is a
    touchy/feely thing. Tight enough to set any switches and loose enough that park
    brake is not dragging. Use blue lock tight on the shaft nuts. Hopes this helps.
    Dray
    Default Bummer.....
    As I see it it is part of the control command and is only sold as a unit and at the cheaper price $410.00. At that price I would tap into the wires and add a push button on the dash...But best find out what the problem is before you venture forth....
    Jul 2008
    Los-Angeles
    do u have extended warranty?
