Brake failure
My break failure light is coming on does anybody know why this is happening it says low fluid But the fluid is good
MMMM i guess
I see you have a double post , so I guess the 1st post was for the front reservoir , and this post is for the rear reservoir ! add a touch of type 4 brake fluid in both tanks , cover the floats ... ( refer too the thread time post 1.07 )
What he said. The fluid level will look fine, but add some anyways.
The double post post was by accident didn't think the first one posted
BRAKE FLIUD
You may want to check your pads also. If they are worn you'll be using more fluid.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
SpyderLovers Founder
Duplicate post. Please post to other thread.
