Results 1 to 21 of 21
    Sep 2016
    Clifton Springs, NY
    Default What Make/Model on your EZ Pass for Spyder?
    We are going to Spyderquest so I registered our EZ Pass in case we take the Thruway. When adding the plate number there was no Make: Can-Am or Model: Spyder listed so I used "Other". Is that how others have done it? Thanks.
    Wayne Bishop
    2015 RT-S Special Series
    2017 F3 Limited
    May 2013
    north boston new york
    Quote Originally Posted by wrb3004 View Post
    when I got EZ pass for my spyder that's how I did it had it for 3 years. as for mounting I put it under front frunk never had a problem reading it.
    When I get my next "Other"; that's how it's going to be listed...
    I saved my EZ-Pass, and will just transfer it over to the new bike.
    Nov 2013
    Central Texas
    Same here, but I am surprised that you were able to register your Soyder on your existing account. If you use an existing car tag on your Spyder, you are probably going to get charged the car rate, not the motorcycle rate. And according to the EZPass website, you can switch the tag from one vehicle only to another of the same type. EZPass has special motorcycle tags which gives you a 50% discount of the cash toll price. But they have changed the rules. You now have to go to an EZPass center (I think that all of the rest areas on the Thruway have them) and provide proof of registration. I didn't have to do that in 2013. This is from the EZPass website.
    Thruway Motorcycle Discount Plan***: Proof of motorcycle registration is required to receive special motorcycle tag. Motorcycles will be charged 50% of the cash toll rate. Cannot be combined with commuter plans. Plan Code: (MTRC)
    Here is a list of places to get an EZPass.
    https://www.e-zpassny.com/en/onthego/locations.shtml
    Hope this helps.
    Sep 2016
    Clifton Springs, NY
    Thanks oldguyinCT, I was looking for info on motorcycles and didn't find it but I was able to register the Spyder on my account. When you add a vehicle you have to select "Vehicle Type" and "M:Motorcycle" is a choice. I could apply for a motorcycle tag but I don't plan on driving the thruway very often if at all. On the way to Spyderquest I plan on traveling route 20 most of the way. On the way back I think I will take route 8 and then maybe jump on the thruway at Utica. Thanks
    Wayne Bishop
    2017 F3 Limited
    Nov 2013
    Central Texas
    Just a point of information, the motorcycle tag works at all toll plazas here in the Northeast, not just the Thruway, and as far south as Delaware and Virginia (which is as far south as we have ridden). So it might be worth it to get one if you end up traveling on any toll roads in the future.
    Jul 2010
    Waterboro,ME
    Up here in Maine we pay by the axle. A motorcycle is 2 axle same as a car. My car and motorcycle plates are identical so I didn't have to get a second unit. It's the same for my wife's truck and motorcycle. No big deal changing them over.
    Active Member ARNIE R's Avatar
    Mar 2017
    Leesburg, VA
    For those of you with EZ-Pass who have attached it to the inside of your frunk lid, do you ever experience it not reading? I was also told by the EZ-Pass people that it needed to be read thru a clear (glass) surface.
    2014 ST-S , OEM Yes Cognac
    Jul 2010
    Waterboro,ME
    I haven't had any problems with my Ez Pass in the frunk. On the car and truck I have them mounted on the built in antenna. Can't see it from the outside. Due to the high speed toll reading they are much more sensitive at picking up the signal. Massachusetts has removed all toll booths on the Mass Pike. If you don't have Ez Pass it takes a picture of your plate and sends the registered owner a bill in the mail. Toll plus expenses for handling and postage. Just like the red light and speeding cameras. Surprise surprise.
    Jun 2008
    BUTLER,PA
    Quote Originally Posted by ARNIE R View Post
    Mine is in the front trunk and it works fine here in Pa.
    Apr 2016
    Albany NY
    When you mount it or position it just make sure it's horizontal that's the way the antenna reads if you don't... Ask me how I know!
    Oct 2015
    Lynden, WA
    Default EZ Pass PA
    I have my EZ Pass registered for my Auto and my Spyder.
    Easy to move between the two vehicles with the velcro fasteners.
    I have it mounted inside the frunk lid on my STS and have no problems.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Mar 2017
    Leesburg, VA
    I'll give it a shot. Right now, I used a velcro strap and a small weatherproof case and strap to my forearm or to the handlebar.
    May 2014
    Benson, NY
    I wear mine around my neck.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Aug 2017
    New Jersey
    Quote Originally Posted by Bensonoid View Post
    I hope you're joking.
    May 2014
    Benson, NY
    Quote Originally Posted by classicvw View Post
    I'm not. Why would I be?
    Sena 20s
    Mar 2017
    Leesburg, VA
    Maybe GoPro and RAM Mounts can get together and design a mount that will stick to our helmet then we stick on the EZ-Pass........
    Aug 2017
    New Jersey
    Not safe.
    Nov 2013
    Central Texas
    WP_000087.jpg Works just fine - except at the Beacon-Newburgh Bridge in NY.
    Invalid Emails
    Apr 2017
    AZ
    Sure glad we don't have toll roads.
    Jul 2010
    Waterboro,ME
    We only have one here in Maine. No toll bridges.
