Results 1 to 15 of 15
Thread: Tear in my seat
    Active Member ABCtriker's Avatar
    Aug 2013
    Vernon Ct
    Default Tear in my seat
    I ride a 2014 RTSE6 26K miles on it and the other day I found a little tear in the seat, right next to the "glove box" It is covered by my sheep skin, but since it gets a little bigger with each ride, I am wondering if there are suggestions on how to fix, patch up, or otherwise take care of it - short of buying a new seat.
    thanks
    Quote Originally Posted by ABCtriker View Post
    thanks
    One of those vinyl repair kits? Since its going on three years, you are probably not going to get a new seat from BRP.
    Covered by sheepskin--put some duct or electrical tape on it to keep the split from spreading.
    Active Member duke50's Avatar
    May 2014
    IL
    Default tear
    [QUOTE=ABCtriker;1293542]I ride a 2014 RTSE6 26K miles on it and the other day I found a little tear in the seat, right next to the "glove box" It is covered by my sheep skin, but since it gets a little bigger with each ride, I am wondering if there are suggestions on how to fix, patch up, or otherwise take care of it - short of buying a new seat.
    thanks[/QUOTE
    Im getting a small tear in the same area on my 2014 RT-S. My seats not covered with sheepskin though.
    Default Bummer...😠
    There were some issues a while back with seats splitting at the seam up front. You could check and see if your in that group or if they will cover it. upholstery shop could fix it but if covered with sheepskin you could do as stated above. Contact cement and a vinyl patch etc...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Sep 2015
    Cemtral ohio
    Default Silicone
    Ive have used clear silicone caulk on tears such as yours on motorcycle & car seats. Stops the tear from getting larger. Worked for me anyway. Just my .02
    Jun 2010
    Las Vegas
    That was before 14. They used to have a seam by the glove box that would come apart but they changed the design in 14.
    Dies your seat bump the glove box when you lower it? You might try adjusting the pin if it does.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Very Active Member Lin's Avatar
    Apr 2013
    Somersworth, NH
    Default Repair options
    There would be two options for me. Either bring it to a local trim shop. They could remove the cover for a repair and reinstall to the seat pan. Alternatively, if the tear is not too bad, I have used tear-aid tape before with great success.
    https://www.tear-aid.com
    Good luck
    Lin
    2016 RT-S Special Series
    2016 RT-S Special , 2 tone black
    Active Member JayD's Avatar
    Oct 2015
    Cumming, Ga
    Default RTS Seat
    I've got a original RTS seat that I changed out for Corbin. I would let it go for $50 plus shipping. Pretty much like new. Black and gray.
    2014 Spyder RTS
    Tri Axis Handlebars
    Big Bike Trailer Harness
    Rivco Front Bumper (Black)
    Rivco Highway Pegs
    Ultimate Seat
    Garmin GPS
    Trailer Hitch
    Aluma XL Trailer
    Stainless Grill Covers
    Cupholder
    Spring Stiffeners
    Rivco Floorboards
    Mar 2011
    oregon
    Quote Originally Posted by Headwrench View Post
    Shoe goo works very well super strong and sticks better than silicone and it stays clear silicone will pick up dust ,you have to be ready and work quick as it skins very fast have the right solvent soaked in to a rag and smooth sounds crazy but I have used it a lot and it works perfect to seal and stop further tearing
    2 happy happy spyders
    Active Member krafael5's Avatar
    loxahatchee, fl. 33470
    Default Seats
    Hi there,
    I also have a tear growing in the same area and also the stitches are coming off. My bike is a 2014 Rts with an extended warranty. I'm going this week to see if it's covered by my warranty. Otherwise I will fix it or search for a new one or even reupholster to leather.
    May 2019
    Alaska/Arizona
    Its a long shot but have you go rid of your seat?
    Thanks Steve
    Apr 2017
    North Central Florida
    I have one available.
    But the shipping from Florida might be a lot of $$$$.
    Active Member GaryinWI's Avatar
    Dec 2014
    Western WI
    You should be able to get a stock replacement seat for a reasonable price from some of the members who have opted for aftermarket seats.
    2017 F3 Limited , Gloss Black with red and carbon fiber accents
    Aug 2018
    Thousand Islands
    Post pictures of the tear, i know for jetksis those kits do nothing and only last few hours of use what i've done in the past is unstaple the seat to get to the tear and glue a bigger patch around the tear, thats the only sure way short of replacing the whole thing.
    2015 Canam Spyder F3-S SE6
    Detachable Passenger backrest #219400703
    Gauge Spoiler #219400531
    Blue Ridge Windshield #219400746
    Hood stripes decal kit #219400711
    F3 Idler Pulley #219800431 / Lamonster roller upgrade
    Bajaron SwayBar
    Elka Stage 2 rear shock
    Arc LED fog lights
    Lamonster F3 bar clamp with Quad-lock phone mount
    Foam Hand Grip Covers
    Tufskinz Peel & Stick Tank Protector Pad (Glossy doomed carbon)
    Linden, CA
    Hi
    Having been in the custom seat business since 1967, I feel qualified to answer your question
    DO NOT again DO NOT use one of the vinyl repair kits you see out there on the market, you will
    hate yourself in the morning if you do.
    Do yourself a favor and take your seat off and take it to your local automotive upholstery shop
    they can fix it in no time and save you the cost of replacing the seat.
