Results 1 to 25 of 28
    May 2016
    Noblesville, Indiana
    Default Urgent - any iseas
    I am on the road and noticed that I could not shift out of 3rd gear when cruising down a rural Highway. Could not shift to 4th nor could I shift down to First. Came to a stop. The bike is in 3rd gear and it idles fine but the throttle is not responsive and again, it's stuck in 3rd gear. I've got a problem. Any ideas?
    May 2012
    North Las Vegas
    What year, model and transmission might help.
    USAF MSgt, Retired
    2018 F3 Intense Red
    Squared Away Lasar alignment, TricLED Headlights, Foglights,Safety Bundle with Turn Module, BajaRon Sway Bar,Squared Away Mirror Wedges, Stebel Air Horn, Dash Turn Indicators, TricLED USA Flag
    2018 F3L , Intense Red
    Mar 2015
    Brockport, NY
    Default possibly low on oil?
    Is there any chance your low on oil?
    2014 RT-S Pearl White
    Feb 2012
    Spring City,Utah
    Do you have an M5 or an M6? If so it sounds like maybe your linkage has either come loose or is dirty. Take the side covers off and check that out. If you have your tool kit with you there should be enough there to do the job.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    May 2016
    Sorry SE5 Spyder ST Limited 2015 20000 miles
    May 2016
    I was able to get home in 3rd gear period when I press the gear shift lever I can tell it's trying to shift gears but it does not shift gears. When the bike is stopped, it idles just fine but as I give it throttle it doesn't respond most likely because it is still in 3rd gear. Any help would be appreciated as I will be tearing off the Tupperware tonight to see what I can find.
    Sep 2014
    USA
    Maybe clutch cable which it may not be or loose foot shift lever since it is a manual model
    Dec 2008
    Syracuse, NY
    He said SE5.
    Default Interesting. ...🤔
    From what you say you are stuck in both 3rd gear and idle...if it is a semi-auto and no throttle response you will have trouble shifting. Oil is a first step and codes if you have them. If Se6 or Se5 you can manually shift with a wrench in your tool kit and get back into neutral. Check the fly by wire if you have it otherwise the older ones had pushme pullme cables. Check the linkage needs to be tight on the shift shaft...it's a start....9
    Sep 2014
    USA
    Quote Originally Posted by wyliec View Post
    He said SE5.
    SM5 is manual..Never mind..
    Electric shift paddle or shift mechanism solenoid could be bad.
    OK SE5 is not manual?? I thought SE6 was semi auto??
    SM designation is for manual. SE designation is for Semi-auto. The 5 designation is 5-speed (998) and the 6 designation is 6-speed (1330).
    Jul 2013
    Vestaburg Michigan
    Same thing happened to me a couple years ago! Shift lever was loose. Manually get it back to neutral then tighten linkage.
    Very Active Member otter28169's Avatar
    Aug 2012
    East Pharsalia, NY
    I had the same issue once with my 2014 ST-S SE5. I had about 4500 miles on since the previous oil change and my oil level was low. It sounds to me like you have the same issue.
    Just sayin'............
    Three in the garage, and I think I can fit at least one more in.....and then we will have to build another garage.
    The roads in NY are so bad that I am glad we bought a Ryker Rally
    May 2016
    Quote Originally Posted by Larry rt View Post
    Larry, you are the man! When I got the plastic off I noticed that the gear shift linkage was loose. So, as you said, I manually got it back to neutral and then tightened it up. I think I am now good to go. I certainly appreciate all the wisdom on this site
    Sep 2014
    USA
    Post #7 stated that too..
    Aug 2012
    East Pharsalia, NY
    I thought it was an SE5????? Did I miss something??
    Sep 2014
    USA
    Apr 2012
    Oregon
    Default check for low oil
    Quote Originally Posted by SpyderUSA View Post
    Bossier LoUiSiAna
    Check the oil you should have noticed some problems well before 3rd gear, now you are there , how are you even starting the bike? By default it is suppose to go to Neutral on start up & requires 2000 rpm to get into 1 or R. How to get this with unresponsive throttle? If you are confident enough to look at & check shift linkage arm, go that route & or find closest dealer & put the BRP roadside coverage to work. FYI you will need your VIN number
    (Suggest contact whatever dealer first, make sure they can fit you in)
    plz let us know what you find
    Jun 2014
    ny
    happen to me last year, low on oil
    Quote Originally Posted by otter28169 View Post
    There's s still a linkage in the SE setup, that can loosen up...
    And I'm glad to hear that you found and fixed the problem!
    Sep 2014
    USA
    Can you please explain where this linkage is located on the SE. I know it has the shaft where a foot shift lever can be mounted but what Linkage ?
    I was under the impression is shifts with a electric solenoid.
    Yup: It does!
    The "Paddles send the signals (eventually!) down to a solenoid.
    That solenoid is attached to the "Foot-Shift-Shaft" , by the linkage; that loosened up.
    Sep 2014
    USA
    Must be internal. There is nothing external that I could tell
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    do the 1330 moels also have a cable too, or just the shift solenid?
    to lazy to look up a diagram.
    [joyce & irvin toms]
