IPHONE PLUG
I NORMALLY PLUG MY PHONE IN THE PLUG IN THE TRUNK BUT HAVE NO WAY OF CHANGING THE SONGS. I PLAN ON PUTTING A SPYDER CUFF AND X HOLDER UP FRONT ON THE BARS. CAN THE REAR PLUG BE MOVED TO THE BLANK SPACE WHERE THE OTHER SWITCHES ARE LOCATED ALLOWING ME TO CHANGE SONGS FROM THE HOLDER.
THANKS IN ADVANCE FOR ANY SUGGESTIONS. THIS IS A 2013 RT LIMITED.
10 foot cable
You could run a 10' 3.5mm to 3.5mm cable from the xgrip to the trunk. I did that early on and it worked for me. I changed setup since then and went Bluetooth.
2014 RT-S Pearl White
BTW all CAPS is considered shouting in Internet land.
The wiring from the plug in the trunk will reach the left side of the "glovebox" .
One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
