Juicebox
Thinking about Juicebox install. How do you know it's set correct and does it help with MPG?
They only thing thats going to noticeably help MPG is a different gearbox or a smaller rear pulley.
Not sure about mpg, will start tracking that on mine, but if you are running the racing air box, it will be an easy install and you can just use the factory settings to make it super simple. Other than that, just push whatever button you want to try the fuel pressue in different ranges like cruise, at throttle, etc.
This totally got rid of my surging issue I had after installing the Hindle, I think I got some extra HP out of it too, could just be a placebo :-)
