Results 1 to 6 of 6
    Active Member NorthAlabamaSpyder's Avatar
    Jun 2017
    North Alabama
    Default Performance Pipe (CAT Delete)
    Ok, so I have this pipe and the Bi City Thunder baffle. Sounds like a loud "Ricer" car. I really only wanted to remove the heavy CAT and reduce the heat. Any way to make it a little more quiet? Thx in advance.
    2019 F3-T and some extra stuff
    Very Active Member ABQSpyder's Avatar
    Jun 2013
    Green Valley AZ.
    I put a RT muffler on mine. Guy I ride with has a Yoshimura his sound nice!
    Active Member Schwingel9's Avatar
    Jun 2017
    Wi
    Default Rice
    They do sound like "Ricers."
    Default CAT DELETE
    I had concerns about noise levels also .... but my RT isn't much louder than when it was stock ...... I did make my own BAFFLE tho........ Mike
    Jun 2017
    North Alabama
    Loudness is not the problem, it is the buzzy sound. I feel like I am driving a Honda Civic with one of those big tail pipes.
    Active Member cmarsala's Avatar
    Nov 2015
    Cary, North Carolina
    Default Exhaust
    Quote Originally Posted by NorthAlabamaSpyder View Post
    I installed the cat delete pipe along with the Big City Thunder baffle, wasn't crazy about the sound, so I installed the can opener baffle from Lamonster along with the Big City Baffle, bike now sounds good and even runs better. Picked up some bottom end torque. The Can opener baffle goes into the long end, it's a press in fit and the BC thunder baffle goes in the curved end. You can get everything from Lamonster Garage.
