Yellow triangle symbol with down arrow to the right
Had my F-3 Limited 3000 mile check at a dealer last week and after leaving the dealer and heading home I noticed down in trip meter space a yellow triangle symbol with a down arrow to the right showed up and went off after maybe ten seconds. Has now done that after I get started on a ride within a couple miles or so, then goes out. Never comes back on unless I shut it down and then start out again like after having lunch. Anyone know what that symbol means?
Originally Posted by akspyderman
and on your new
Can you furnish a picture? Is your machine in ECO mode?
I am not in ECO mode. Have not been able to get a picture of the symbol. It come on while ridding and could not stop and get a camera out before it goes out. Only on for up to ten seconds or less. Like I said, its a yellow triangle with a diagonal down arrow to the right. The symbol only shows up in the little trip meter space. Strange. I'll contact my dealer when he opens again in a couple of days if no one has an answer.
The triangle is what made me think about ECO mode. Did not know if you were color blind--as the symbol shows up in green. Just a long shot guess on my part.
Will have to wait for the explanation about the yellow triangle.
If you can get a picture, it would be good. Over & Out.
Nope, not colorblind yet. It is definitely a warning symbol of some kind.
Little checking..
Have you checked the manual..? They generally have a list of all the symbols and what they mean...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Originally Posted by UtahPete
Does the triangle have an exclamation mark inside it?
Not sure what you mean by an arrow symbol diagonally down and to the right; is it like this one? Also, what color is the arrow?
That's the arrow. Color is black I think. I do believe the triangle does have the exclamation mark inside. The thing comes on for short of time its had to tell, and its kinda small from sitting in the seat.
If we figure this one out it should be good information for others down the road!
Okay, I'll bet what you are seeing on occasion is some version of this;Traction control icon.jpg
If so, it is an indication that your traction control system is kicking in. That's why it's only intermittent.
2014 RTL Platinum
Okay, I'll bet what you are seeing on occasion is some version of this; Traction control icon.jpg
OP - Would you let us know the outcome? Thanks.
2014 RTL Platinum
Here's a thought....
could be a symbol for the passenger is missing...just letting you know... has anyone else had this..?? I'm guessing not...looks like your in charge of this one and will have to let us know if even they know....
2012 RS sm5
As soon as I solve this I'll update everyone. Thanks for the help in trying to come up with an answer. Damn strange that the manual does not show or explain all the symbols they've installed in the computer.
Payotee did you see post #9 ?
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
I've just been through the WSM and found this:
6) Trip Meter
Time. distance travelled and average speed since the last reset. Two trip meters are available and they are identified as "A and "B". To change units, refer to P R E F E R E N C E S S C R E E N . As a second function, the trip meter may display an icon to inform the driver of a malfunction.
However, I can't find a list of the malfunctions it may display but I'll keep hunting.
Defintely looks ike it's seeing a fault though so may be worth pulling fault codes.
| 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
Oh, forgot to say that I have tried to pull the code and nothing comes up.
Pages 112 and 113 of your operator's manual show the error icons that can appear on your multifunction gauge but the list does not include the display you are seeing.
It won't if it is indeed just a notification that the anti-slip is kicking in. See my earlier post about the icon...
It's not the VSC icon - that's in the analog guage on all F3s and it looks like this:
They are just the ones that appear in the analog gauges and have a dedicated lamp.
The icon he's getting is in the trip area in the colour gauge on his LTD. The manual says malfunction icons can appear there but doesn't give a list of them.
This is where he's seeing the unknown icon (highlighted area):
Does the operators manual for the LTD (I only have the F3-S one) give any icons that can appear here? The WSM I have covers the 2016 colour gauge but doesn't give any icons for this area.
F3 LTD operators manual
Originally Posted by monkeyboymorton
Cheers That's a useful site.
OK, I've looked in the 2017 manual and the only fault it lists that shows in the digital gauge is this one:
Could that be it?
No sire, not even close but nice try Here is the latest non update. Another week has passed and I still have no answer from either dealers or the factory!! Now that's quite disappointing, don't you think? ON this coming Thursday I have a date with a Can-Am dealer for going further into the issue. I suggested they contact the HQ in Canada and get a ticket number started for an answer before I got there. ( That's what BRP said they would do if I contacted a dealer). So I guess I'll have some interesting things to say after I return from that meeting.
This may already have been asked but did you, or could you, get a picture of the symbol?
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I wish that I could but since its only comes on while I'm ridding and only stays on for maybe 5 to 10 seconds, it's quite impossible unless I want to risk wrapping myself around a tree. You would think that this would be an easy thing to get an answer to, but I guess BRP does not give too much of a rats patootie. I've called BRP HQ and ask them about it and they said ask you dealer and if they don't know they can get an answer from us here at HQ, but we can't give you one. So I called two dealers so far and asked them to solve the problem. One called me back after a few days and said it not in the mechanics manual they'd call BRP and get back to me asap. A week later I still have no answer. What a way to run a business! I'm patient but when you have a warning signal show on the dash it would seem to most people that it's important to know what it means.
