Results 1 to 22 of 22
Thread: SM5 vs. SE6
    Jan 2015
    southern WI
    Default SM5 vs. SE6
    Yeah, I know the difference....question is: I had an SM5 and used Rotella T6 with great success....now I have a brand new jug of Rotella T6 left over on the shelf, but now I also have a 2016 SE6. Have people used Rotella T6 in the SE6 with success, without any "ill effects" such as slippage? By no means am I starting an oils debate guys, only asking specifically about Rotella T6 in the SE6 transmission. If I should dump it in the recycle barrel I will. It's only $21 after all.
    2016 RTS , Pearl White
    Default No problem....
    the only difference is the mechanics of the clutch. The oil is the same (meeting all spec's) in both.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    Are you talking the Rotella T6 diesel engine oil?
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Jan 2015
    southern WI
    Quote Originally Posted by BoilerAnimal View Post
    Yup.
    May 2016
    Might just be my new oil!
    2013 RT-S SE 5
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    i think jc thorne says he uses it in all his spyder changes. i carry about 4 gals
    all the time for my mowers an powersports stuff. there are others her that are using it.
    will probly try it after my brp oil is gone.
    [joyce & irvin toms]
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default Used BRP Syn in the 11 RT SM5 - Now Rotella T6 on the 1330's
    Had 40,000+ on the Rotella on wifes 15 RTS and now using Rotella at 10,000 on her F3T SE6. Here is the last oil analysis on the Rotella from my 15 RT SE6 at around 25,000 miles
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    That's a good analysis report. The oil has sheared down some but it's solidly in the 30wt range. Steve from BRPCare explained a couple years ago how oil in engines with wet clutches will shear down some early in the life of the oil and then stabilize.
    Apr 2017
    North Central Florida
    I have heard a report that the T6 now has some moly in it and might not be good for wet clutches.
    BUT.....that was only one report several months ago and I've seen no substantiation of that yet.
    Some searching might be in order.
    Nov 2012
    Pueblo Colorado
    Default Yes there is molybdenum in varying quantities in most all oils
    I shied away from it on our old 11 RT SM5, but used it without any problems on my 07 Honda Shadow for 36,000 miles, and about 80,000 miles on the SE6 trannies/engines on 3 Spyders.
    All I THINK I know is - Stay away from energy conserving oils in motorcycles; change oil regularly (as advised by manufacturer); Ryde More: Worry Less.
    If you want some more reading on different oils from Blackstone Labs https://www.blackstone-labs.com/News...uly-1-2017.php
    They say use what works for you
    Very Active Member Ron2andia's Avatar
    Jun 2012
    Phila
    Live, Love, and Ride! God Bless!
    Jan 2015
    southern WI
    Thanks everyone....I'll be dumping that jug of oil in the Spyder tomorrow then while it rains......
    Apr 2017
    Quote Originally Posted by AeroPilot View Post
    Yes but if they change the formulation, what worked yesterday might not today.
    And I do NOT buy your claim about moly additives........at least not in oils designated for motorcycle use.
    All bike oils that I am familiar with contain NONE because no matter how small the amount, it tends to "stick" to the clutch plates and accumulates over time.
    Default THESE TWO OILS - AND MOLYBENDIUM
    Amsoil has the lowest amount followed by Valvoline 4 T -stroke, both are full synthetic ..... both have some Moly but very little. I saw this on a test chart of about 20 popular Mtc oils .......Mike
    The 'friction reduction molybdenum' (MoS2?) that we all learnt (quite rightly too!) that you shouldn't use in motorcycles with wet clutches some years back is just a little different to the oil soluble liquid 'anti-wear molybdenum' (MoDTC?) that's now present to some degree in pretty much all oils these days, altho admittedly it's often used at very small concentration levels, but it's still there!....
    Admittedly the link below is from Royal Purple, but that aside, it still helps shine a little light on the subject..... especially if you dig a little further & check out other sources too!
    http://www.royalpurple.com/blog/the-...otorcycle-oil/
    Aug 2012
    Central Coast, CA
    To my understanding T6 didn't change it's formula, it changed it's certifications and is now rated MA2, which is the modern motorcycle oil rating with catalytic converters.
    2020 RTL SE6
    Apr 2017
    Quote Originally Posted by KX5062 View Post
    That happened a couple of years ago.
    What I'm talking about happened only a few months ago.
    The previously mentioned different "moly" products might explain the confusion.
    The problem comes with the "dry" additive which is molybdenum disulphide.
    If it was the other kind that got added to T6 then it shouldn't be a problem.
    For those who use T6 in a motorcycle, you might want to look closely at the label when buying a new supply.
    Anything older than 4 months should be fine regardless.
    Default MOLY
    ... This article was written in 2010 ..... so it's seven years old ....... Mike
    Apr 2017
    And you think that is important, why exactly ??
    Default WHY - EXACTLY
    Because I saw it on the " INTERNET " ...... Mike
    Nov 2012
    Pueblo Colorado
    Default Last jug of Rotella had the JASO MA/MA2 designation
    Since the label still says MA2 it should be good for my CAT and my clutchDSCN2157.jpg
    May 2016
    mt morris il
    Quote Originally Posted by Mazo EMS2 View Post
    keep me posted about your thoughts on it. my dealer said he puts amsoil in for customers
    who bring it, but hadnt ever done rotella. i used mobil 1 4t in my vtx. tried rotella in
    the vic , but went back to their oil. didnt think it shifted as well. have the t6 in all my
    mowers and my honda rubicon since new in 09. no probs. jc thorne says it works for him and his customers.
