100 watts LED Headlight on F3
Hi,
I'm looking for a better headlight for my F3-S. Can I install 100w LED without get housing damaged ?
thanks for your help!
Originally Posted by Spyder555
Hi, I'm looking for a better headlight for my F3-S. Can I install 100w LED without get housing damaged?
I wouldn't do that. If you need more light, install driving lights such as these from TricLED; https://www.tricledusa.com/_p/prd1/3...99s-spotlights
2014 RTL Platinum
100 WATT - - LED ????
Hi,
Are you sure what type of bulb you are talking about ...... I've heard of 100 watt " HALOGEN " bulbs ....LED's are generally rated in " LUMEN's " .......... I had 100 watt halogen's in my RT, with no HEAT issues on the plastic headlight COVER - but the OEM plugs disintegrated, I cured that problem by changing those plugs to CERAMIC ones ..... But the 100 w halogen bulbs weren't anywhere near as bright as the LED's I bought at TriClid ........ and the LED's won't burn out in your lifetime ............. Mike
Mike,
I'm taking about 100watts LED Headlight that provide 10000 lumens. This LED comes with fan integrated. I'm hesitating to install that. I order from Ebay. Thanks for your comments.
10,000 lumen's = 100 watts
Mike,
OK now I think everyone can understand what bulbs you want to use ..... I can't say exactly what the heat output is between the two ..... but LED's run substantially cooler ........... Mike
Originally Posted by UtahPete
How about providing a link so we can see what you're referring to. Thanks.
here the link:
http://r.ebay.com/eUCq8O
thanks
It seems that they can get up to about 175 degrees Fahrenheit...
Hi, I'm looking for a better headlight for my F3-S. Can I install 100w LED without get housing damaged ? thanks for your help!
This thing has a built-in fan! I sure wouldn't want that in my bike.
2014 RTL Platinum
