Results 1 to 13 of 13
    Active Member wd8ajj's Avatar
    Las Cruces NM
    Default TIRE PRESSUE USIBG fEDERAL TIRES Help
    i JUST INSTALLED A SET OF Federal 165/55R15 tires and filled them to 23 PSI. I now that this tire was a preferred due to postings but lost what people were running them as pressure. Was 23 the optimin setup?
    Gary
    I'd start my testing at 20psi, and be prepared to adjust them downward a tick or two...
    The OEM Kendas kind of need a bit more air in them, in order to keep the rims from hitting the road!
    Nov 2015
    Myerstown, Pennsylvania
    Do a search. Lots of threads & info on that topic.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Las Cruces NM
    Seen anywhere from 18 to 25 PSI so guess 23 is a good starting point. For auto usage they want 32PSI. Think if they put that in I could do wheelies with the bike, but then bounce all over hitting train tracks and potholes. Will stay at 23 and see if that works for now. Not riding a lot being 99 outside and rain every afternoon. Next big trip id to the Grand Canyon in September. Red Rocks Rally.
    Gary
    Jul 2015
    Saint Michael, MN
    I am running the AZ01's at 18psi. I started and 16psi and bumped it up to 18psi. We do lots of high speed interstate, two-up riding.
    Gunner
    Las Cruces NM
    maybe reset to 20PSI if a rough ride.
    Not sure of the difference in Federals but these are the 165/55R15 - 75V Max Performance SES EVO.
    Treadwear 260
    Traction A
    Temp A
    Default SRONT TIRE PSI
    Quote Originally Posted by wd8ajj View Post
    Gary
    In comparison to a car your Spyder weighs very little ..... however you have a tire that can support approx. 1300lbs ..... I say 15-16 psi so your tire will have more traction in the rain, plus if the tire is more compliant your ride will be less harsh when hitting bumps or potholes ..... A jarring front suspension is not good for keeping your alignment where you want it ....... Mike
    Very Active Member DJFaninTN's Avatar
    Panama City Beach, FL
    16psi
    2015 RT Limited Intense Red Pearl
    Sep 2014
    USA
    I been running mine at 19 psi
    Jun 2010
    Las Vegas
    I usually run my Formozas at 19 to 20
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Active Member lewisalice's Avatar
    Brooklyn NY
    Gary
    I have the same tires i keep mine at 20
    Sep 2016
    Clifton Springs, NY
    I have the Federal Formoza's on the front and a General Altimax on the rear. I run 18# all around.
    Wayne Bishop
    2015 RT-S Special Series
    2017 F3 Limited
    Invalid Emails
    Mar 2017
    Cloudcroft
    I've got Federals over here in Cloudcroft I've yet to install. Be interested to hear what you decide for pressure settings. It's on mu list for next week, though.
