Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Horn Location
    Active Member ttrac's Avatar
    Sep 2015
    Mass.
    Default Horn Location
    Does anyone know where the horn is located on a 2017 RT S ?
    2015 RT SE6 LIMITED, Black
    Tri Axis Handlebar,
    Ultimate Mid Rider Seat with Fuel Door
    F4 Wide Tinted Windshield, with Vent
    Tric Led Mirror Signals
    Stebel Nautilus Compact Twin Air Horn
    Jun 2013
    queens ny
    on the 2014 it was on the left side behind the side cover
    NO BIKE AT THIS TIME
    Sep 2015
    Mass.
    Thanks John but it is not there on the 2017
    Tri Axis Handlebar,
    Active Member Docster's Avatar
    May 2017
    Perry Hall, Md
    Do a Google search of 'Horn location of 2017 Can Am Spyder' to find all sorts of references and videos
    2011 Spyder RT-S
    LtCol, USAF Ret
    Proud Patriot Guard Rider
    2011 RT , Yes Blue
    Invalid Emails
    Jul 2014
    Rotonda West,FL
    Quote Originally Posted by ttrac View Post
    Right in front of your left foot behind that cover on the 16 RT
    Sep 2015
    Mass.
    Thanks CapeSpyder it is there on my 2015 also but not there on the 2017. Don't understand why they would move it on the 2017.
    Tri Axis Handlebar,
    Sep 2015
    Mass.
    Thanks Docster , that was he first thing I tried but to no avail. Came up with everything except the location on the 2017's.
    Tri Axis Handlebar,
    Invalid Emails
    Jul 2014
    Rotonda West,FL
    I have to ask, when you honk it where does the sound come from ?????
    Sep 2015
    Mass.
    It sounds as it is coming from the right side. Pulled of the right panel by the right foot and could not locate the horn. If no one knows the location I guess will have to start pulling off some panels. Just thought someone would know it's location.
    Tri Axis Handlebar,
    Sep 2013
    Houston
    I have not had a 17 RT in the shop yet but could they have moved it to the right side near the front a arms like on the F3?
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Sounds logical, since using the same pre-built wiring loom will save Can Am $$ in the manufacturing process.
    2020 RTL SE6
    Feb 2017
    On my wife's 2012 RT Limited it's buried under the left side fog lamp. On my 2015 it's, as mentioned, behind the lower side cover just ahead of my left foot. I changed my horn in a heartbeat; not anywhere near as quickly on my wife's.
    Why did they move it? My guess is so owners wouldn't have to disassemble the entire front of the machine to reach the horn! Then again, maybe it's just a Canadian thing. Or maybe there isn't a horn and you have a very vivid imagination. Or, technology being what it is, it could be a "cloud horn."
    Jun 2013
    queens ny
    have you found the horn, i am wondering where they put it
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    AKA Jud Smales, Four Year Spyder Ryder!
    "Quando Omni Flunkus, Moritati"
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Driver & Passenger Gel Pads in Seat
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Break Stripe Kit from Wrap My Spyder
    2016 RT-S , stock not yet Pearl White
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Docster View Post
    I tried this. Couldn't find any links to anything relevant (except the link back to this thread!).
    Is this something Lamont could answer? Also, the thread name is kind of ambiguous; is there any way to make it more specific and grab attention of forum members that might know the answer?
    Like "Where did they put the horn on a 2017 RT?"
    2014 RTL Platinum
    Active Member CrashDavis's Avatar
    Jun 2017
    Niceville, FL
    Default Horn
    On my '17 RT-L, when I took off the left side panel to install one of Lamont's foot pegs, the horn was staring me in the face. I cataloged it in my brain as I'm likely to replace it for a louder one in the near future.
    2017 RT Limited
    Jun 2013
    queens ny
    Quote Originally Posted by CrashDavis View Post
    that is where it was on my 14 rt
    Sep 2013
    Houston
    So same place as on earlier RT years
    Sep 2015
    Mass.
    On my 2015 RTL if you remove the left side lower panel the horn is right there, however on my brothers 2017 RTS there is nothing there just empty space. He asked the dealer and they didn't know where it is located. So the mystery continues, " Where is the Horn "
    Tri Axis Handlebar,
    Jul 2014
    Mint Hill, NC
    I was at the dealership today and looked through the honeycomb on the left side and there it was, same place as on my '14.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Sep 2015
    Mass.
    Well it is definitely not there on his 2017 RTS
    Tri Axis Handlebar,
    Nov 2015
    I just looked at the diagram on discounthondaparts & it looks like it might be located on the right side somewhere around the parking brake motor. Hope that helps.
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Nov 2015
    Default Did you find it....
    Did you find your horn????
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
    Sep 2015
    Mass.
    Not yet, will be pulling panels off this coming Saturday to replace the horn. Will post location of the horn when we are done.
    Tri Axis Handlebar,
    Sep 2015
    Mass.
    Just a quick follow up, on a 2017 RTS the horn is located almost dead center on the a frame. Pull off the skid plate and one small panel and there is the horn. I have no idea why they changed location once again. Once we found the horn it is an easy swap. Hope this helps someone out.
    Tri Axis Handlebar,
