Starting issue
I have a 2013 RT-S. It sounds like it wants to start but does not quite roll over. Radio, lights , dash all come on. It does not have the click, click sound of a dead battery but I had it checked anyway and it tested fine. Do the wise members of SL have any suggestions for me?
Your battery probably isn't nearly as "fine" as you think it is...
Get a new one!
Little checking..
While back we saw some starter motors have the magnets come loose. If your battery tested good under load, not just voltage, and there is no clicking you may have a solenoid or starter problem...
2012 RS sm5
How was the battery checked? By who? What where the results? Pass/fail is not good enough here. At what current draw, for how long, what was minimum voltage?
By your description the battery may be dead. It could be bad. It may not be the battery at all but a loose connection.
2018 F3 LIMITED
This. Also hooking it up to a charger for a few hours can tell you a LOT.
If it springs to life after that, either the battery is just shot or the charging system has gone bad ......or both.
But most likely just the battery.
Almost hate to mention: that those symptoms can also be caused by a locked up engine, sometimes due to liquid fuel in a cylinder or coolant.
Hoping that is NOT your problem.
Try jumping it off your car, no need to start it, if it starts you ether have a dead/ bad battery or bad connection.
Thanks for everyone's insight. The battery was tested at Batteries Plus. The test lasted all of 45 seconds. I keep it on a tender to keep the charge up.
I'll start with trying to jump start it. That will tell me a lot.
