ignition will not turn with key in any direction
I am new to the forum. I just bought a 2010 Rt with 731 miles on it. Drove it home and the ignition won't open frunk and will not open seat. Will not turn for dash cycle.. Help?
Try pushing the key up and down vigorously, put a drip of oil on the key first, with so few miles clock it could be a bit sticky, mine has been on many occasions, every time I put my key in I always push it down 2 or 3 times before turning
Also try sitting on the seat and see if the key will turn or push the frunk lid down and try, if something is jamming one or the other it won't turn.
will the key turn at all? just to tun on the ignition?
Failing the above it's off with the tupperware and investigate.
Hope this helps.
2014 RT Std
Floor and Highway Boards
50$ GPS connected to oem loom
Trunk & Frunk Liners and lights
Frunk and dashboard power outlets
Front supension LEDS
Cup holders
Glovebox light
Turn signal LEDs in mirrors
12 volt coffee maker
Passenger hangrip muffs
Ignition lock light
Windscreen wiper/ baguette holder
If I wasn't so cleverI wouldn't need to be so good looking.
thoughts
hey tim , are you getting at least the feel , of the frunk , or seat release trying to open ? a little resistance on the key , like the spring is pushing back ? on one other thread here the front trunk { frunk } they had a trunk not opening , and had too have some one push down on the lid too the front , while the other turned the key to release the latch ... seems to have been the rubber seal inside was off the housing that holds it in place and this caused the latch too be a bit tight ...
I have tried all your suggestions and thanks.
I added a third brake light (t-tap connections), and a Garmin 660 GPS. made these additions before 3rd July 17. Went to gas station fueled up, and after fueling tried to turn key, spyder key would not turn, embarrassing had to push Spyder from gas pump. waited four hours on tow. Wheels were moving and the wheels just stop rolling and start sliding during the tow. Spyder has not started since the third. If the key does not turn today when I get home. I wil have it towed to the dealership.Also, talk to prior owner, he says never had a problem with Spyder at all. Oh, pulled up codes 3rd of July 17 P0000. Hmmm! I wil get you guys some pics, also. Thanks in advance.
Bummer...
First off welcome to both the spyder world and this site. the code you found is actually a non code. It is like a default when resetting. If the key is not turning then jumping on the seat or frunk lid will not help. I would spray some WD40 in or along the sides of the key if it does not come out so it can penetrate the mechanisms. After doing all the above it may be a dealer thing...
2012 RS sm5
Are you saying that the ignition key worked to start the bike and to open the frunk and seat for you on the way home, but now it won't do either? The question isn't very clear to me.
2014 RTL Platinum
The Spyder should NEVER be towed with wheel or wheels in contact with the ground!
2014 RTL Platinum
Ozzie Ozzie Ozzie
Ignition switch will not turn or do any functios.
Well, I have tried flashers, work fine saddlebags, work fine, key will not turn at all. Dealer is closed today. Horn blows fine. Battery charge shows green. I just don't know. I only have one key. Drove it home with the one key that I have. Thanks in advance.
On a recent trip a member put his key into his Spyder RT - The
key would not go all the way in and then would not come out it was somehow jammed
We tried several attempts to get it to either go in fully or get the key out Nothing worked
We were expecting a recovery trip to a dealer as we were on a planned ride out with them
It was a Sunday and they were closed but the dealer went to get some tools and WD40
after spraying the key with a lot of WD40 he got the key out
There was no further issues after that
It may pay members to lube the ignition switch from time to time to avoid any problems
Not sure if this will solve your issue but hope you do get it sorted
Eddie Sheppard
Poole Dorset UK
Get a Spyder - See the World
What year bike was this one? There was a TSB put out for the 2014 RTs about ignition switches jamming up like this.
oil in key cylinder
Hope this helps.
I would like to add just a bit of info regarding oil on the key. I work at a hardware store and have learned not to use any oil in a key cylinder. Instead, use powdered graphite (or spray graphite), TriFlow or similar type of lubricant. I think LPS makes a lock lubricant as well. The reason not to use oil is because it tends to attract dust and dirt which will prevent the key cylinder pins from working as expected.
Lock-Ease makes a powdered and spray version of graphite lubricant.
2010 Full Moon Silver RS SE5
Bob I believe his is the 2014 1330 RT SE6 model
i don't suppose you have a copy of the TSB or a link to find it
Thanks
Eddie Sheppard
Poole Dorset UK
I'll see if I can find it...
But I can't promise much: this goes back over three years into the archives.
Bob I believe his is the 2014 1330 RT SE6 model i don't suppose you have a copy of the TSB or a link to find it Thanks
Try going to this link and put in your VIN to see if that is an open recall for your bike https://can-am.brp.com/spyder/owners...s_list_start=6
Or, try filling in this online form for customer support https://can-am.brp.com/spyder/form/contact-us.html
2014 RTL Platinum
If you read the first post he stated that he bought a 2010 RT
Semper Fi
Thanks
This Thread should have you covered.
http://www.spyderlovers.com/forums/s...gnition+switch
