2015 RT SE6 wont shift out of neutrel
My spyder wont **** out of neutral int first gear. I can shift into reverse and it works fine. The engine rpm's appear to lift alittle but wont move out of N.
Are you pressing the brake?
2016 Can Am Spyder RT-S SE6
Not shifting
Check the arm arm from the shift cylinder if is out of place , that apen on my
goodluck
SHIFTING
I had the same problem on my F3-S last year. It turned out to be the reverse actuator switch which the dealer replaced.
2020 F3 Ltd
Spyderpops Bumpskid
I had the same symptoms, just as JKMSPYDER, I also had the reverse actuator switch replaced. By the way occasional "E" I got before the switch was replaced has never happened since. Was a bear for the tech to troubleshoot even with BRP's help. Tech eventually figured it out.
2014 RTL SE6 Pearl White, Mfg. date 1/28/2014
BRP heated seat, BRP backrest, SpyderFlap, Tricled mirror turn signals, KOTT Grills, BRP adjustable side air vent, Bumpskid, Bajaron sway bar and heim links, Spyderpops belt guard, Tricled day lighters, Tricled fender LEDs, CD HMT running/brake LEDs
Thanks for the help. I've got it booked in next week, and have ordered actuator and cable ahead of time assuming that is the problem. My dealer sayes they have to diagnos the problem first and then take picture of malfuctioning piece and wait to see if they agree that its warranty then order parts and wait again. Summer will be over by the time its fixed if i wait for brp
Please let us know what the outcome is.
2020 F3 Ltd
Spyderpops Bumpskid
