Required tools
I will be installing a set of Diamond R armrest this weekend, aka, the wife's first farkle. Looking under the seat, I noticed that the screws have a Torx head on them. What is the size of the Torx? Can you guys and gals recommend a starter set of tools I should buy. Mostly for the easier farkling. Thanks in advance for the wisdom.
2016 RT-S Special Series
Spyderpops LED Bumpskid
LED headlights and fog lights
Ozzie Ozzie Ozzie
The OE tool bag (under the seat) should have all the necessary starter/basic tools in it, didn't you get one of them?
For panel removal to make pins easy
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
i went to sears and picked up a t handle torx set 7 piece i think
Harbor Fright has a nice set of assorted bits in a plastic case for around $10. It's a blue case with clear lid.
2010 RTSM5
Leatherman tool, bicycle hand pump, vulcanizing kit, cell & numbers to call for help, credit card & cash.
My tool kit is in the bottom of the top compartment held with velcro. Anybody else have theirs in there??
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
That's where I found mine, in the bottom of the trunk.
And it has just the basic stuff that is needed for maintenance. I'm planning on adding a few items like pin pliers for those plastic pins & extra pins too. I should get rechargeable tire pump too.
BajaRon Sway Bar
Foam Grips
Shorty antenna
Here is what I carry, It may not be enough, or too much, but it seemed reasonable at the time.
- 12-volt air Compressor
- Tire plug kit
- Assortment of cable ties (zip ties)
- Screwdriver with interchangeable heads, including a couple of torx heads
- Ratchet with some basic sockets
- Wire cutter
- Small crescent wrench
- Needle nose pliers
- Extra oil, coolant and a small funnel
- On long trips extra gas (been caught on a ride where planned stops did not go as planned
All of the tools fit nicely in small containers in the trunk and do not take up much room. The oil, coolant and extra gas takes up one of the saddlebags.
Regards,
BitSlayer
2015 Spyder RT Limited - Perl White
- Having fun with my knees in the breeze
I carry near the same i might have to add the last 2 items
A flat tip screwdriver is really all you need to remove the pushpins. Pushpin pliers are okay but they take up more space in your toolkit than a flat tip does.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Regards,
BitSlayer
Ditch the 12 volt air compressors or bicycle pumps and get one of these from Lamonster: http://www.lamonstergarage.com/lamon...r-pack-silver/ You'll be glad you did!
Like Ann said, a flat top screwdriver works just fine for removing the pushpins. I put a bend in mind so it works very easily.
On the road again...........and forever young!
2013 RT-S SE 5
Yesterday is a cancelled check.
Tomorrow is a promissory note.
Today is cash.......spend it wisely.
I have a really nice toolkit for my Harley but the zipper broke. So I just bought this - love that it rolls up with a velcro strap. Pit Posse Motorcycle ATV Metric Tool Kit
2015 Can Am Spyder RT-S
Burgundy Seat
RT-622 Trailer
2006 Harley Ultra Classic - sold
1985 Honda Magna - sold
2015 RT-S , large brake pedal Silver Platinum Satin / Steel Black Metallic
why buy when there was a complete set with the bike?????? look under the seat.
BIG F
BIG F
For my money with the "complete" tool kit you'll have a helluva time replacing a headlight bulb if you need to do so on a long trip. While there is a 10 mm "socket" in the kit one will play hell getting the upper center headlight mounting bolt out without a good socket and long extension. I recommend a 1/4" drive to save space. I carry two spare headlight bulbs even though I have LED headlights and fog lights.
' in the kit
