Results 1 to 23 of 23
    Active Member Kredab's Avatar
    Oct 2015
    Iowa
    Default Can Am Stinger trailer
    Has anyone used one of these to pull a Spyder Rt? Seen one in action? Advantages or Disadvantages? Let me know what you know and Thank you for the information
    www.stingertrailer.com
    2016 RT-S Pearl White
    BRP Driver Backrest
    Lamonster Spyderdock, (2) Spydercuffs
    Magic Mirror w/Doc Humphreys tethers
    (2) Rokform phone mounts
    FOBO
    SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
    Lamonster LED headlights & foglights
    Spyder Pockets
    LED front fender kit -running & turn signals
    Custom Back off mudflap
    Vinyl nameplate & 1330 triple decals by New Image Signs
    Custom RLS exhaust
    Hogtunes speakers 5 1/4 front and back
    Memphis Powersports Amp
    Her name is "Purl"
    2016 RT-S , white
    Sep 2012
    Junction City, KS, USA
    The Spyder models width varies somewhat, and they show it with an RS. I don't know how that compares to an F3 or RT.
    Active Member Chasinsparks's Avatar
    Jul 2016
    Woodbine, Maryland
    Default I dont think so
    Watching the video, I don't think an RT will make it without ripping off the front end.
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    I occasionally ride with a person who owns a stinger trailer.
    He tows his RT with it.
    No issues loading or unloading spyder and it folds up out of the way when not using it.
    He used the trailer to the RT from Ontario,Canada to Spyderfest in Springfield MO.he also used the trailer to go to Homecoming in QC.
    No problems at all.
    seem to be very well made and seem that no additional ramps needed. I can visit factory to answer any questions as it is close to where i live just PM me.
    https://ca.stingertrailer.com/produc...pyder-trailer/
    Jul 2011
    Oklahoma
    Does the RS have more ground clearance than the RT? One way to get around that is to build some blocks that the front tires could ride over until the back tire is on the ramp and clearance is no longer an issue. I have seen others do that to load their Spyders on other types of trailers.
    Default THE STINGER
    If that trailer has a SUSPENSION ...... I can't see it ........... Mike
    Oct 2015
    Iowa
    Default stinger
    I don't think it does
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    Aug 2013
    Northern California
    Default Disadvantage
    The big disadvantage is that you won't be ryding the Spyder!!!!!
    Very Active Member ABQSpyder's Avatar
    Jun 2013
    Green Valley AZ.
    For a few hundred dollars more I'd buy a DropTail! IMHO
    Oct 2015
    Iowa
    Quote Originally Posted by ABQSpyder View Post
    I do like the drop tail but it is about 800-1200 more depending on options. I also need to try and keep weight down as possible, because there was no plans to get a bigger vehicle to pull....Stinger was 495 lbs , drop tail was 644 pounds. Of course if money wasn't a factor, I would love the Ultimate trailer.
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    Seems a little pricey to me for what it is. Also, I'd be concerned about how solid the hinging aspect of it is. If there's no torsion or spring suspension on it I'd be leery.
    Active Member LifeLongRider's Avatar
    Aug 2018
    Florida
    I've been considering a Stinger trailer ($2599 delivered) for some time now because if I do buy a trailer I pretty much have to have a folding trailer which will store upright. I live in a gated deed restricted community where no RV or trailer storage of any kind is permitted . . pretty much eliminates anything that won't fit in my garage (along with two cars and the Spyder). Previous posts are correct in that the Stinger does not have any suspension, just a rigid axle (see pic). That, coupled with the fact that it takes two grown men to unfold the trailer due to it's weight has been a deal breaker for me . . so far. On the positive side, they are now powder-coated.
    As for the "no suspension", Stinger says "the pneumatic characteristics of the 13" radial tires and the suspension of the Spyder itself provide for a safe smooth ride". Yea right !
    Surely there's someone on this forum whose owned one of these trailers. I'd like to know how they tow and whether the "no suspension" aspect is a hinderance or does it even matter. I know that Aluma used to make a folding trike-trailer but it's not available anymore and I can't find any other folding trailers suitable for a Spyder (if you know of any, let me know). I should add that Kendon also makes a folding upright trailer for the Spyder but at $4199 it's cost prohibitive. As always, any help/advice is greatly appreciated.
    2019 F3 Limited
    2019 F3 Limited , Oxford Blue
    Florida Swamp
    Pretty nice looking little trailer and you could pull it with a small car, but dang, it cost me about the same thing to build my 16 foot equipment trailer and it will haul the tractor, the Spyder, and lots of other stuff (not all at the same time). If you do a lot of towing, it might pay to have a small trailer just for the Spyder, but the only time mine goes on a trailer is when it is broke down.
    Only time the Spyder was ever on the trailer so far is the day I brought it home from the dealer.
    2019 F3-S , Black & Silver
    Mar 2019
    Fla/NJ
    Don't know about use for a spyder but I have used a stinger trailer for the past 10 years to tow my motorcycle. Apx 3,000 miles per year with no problems. Grease the bearings and go.
    May 2013
    Apex, N.C.
    I would consider the one by Kendon, or Towblazer (generic version of the Kendon). I had one, and decided to sell it like a dummy. Now I wish I could find another.
    Nov 2008
    Canada, Ontario
    I bought one of these and love it.
    https://apogeetrailers.com/
    I consider the stinger but didn't go for it for a number of reasons:
    - It has a dedicated function. AS such it has little resale value / opportunity
    - It's steel as opposed to alu
    - It's cheaper but not cheap
    The Apogee is all alu. You can tow other stuff with it. It's about 3 feet thick when folded. The width depends obviously on the trailer selected. I have the 5 X 10. The F3L fits within 2-3 inches. An RT would required a 6 X 10. I had to do something with the ramp to avoid scraping the nose of the F3L.
    GL
    J
    2018 F3 Limited black, dark
    Jun 2015
    Ritzville, Wa
    Quote Originally Posted by Kredab View Post
    Found a video on youtube about this trailer
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Jun 2015
    Ritzville, Wa
    The trailer comes on a pallet when it's delivered.
    Greg Kamer
    Active Member Gilly's Avatar
    Dec 2019
    Musquash , New Brunswick , CANADA
    I have a Stinger , came with the bike. Your all right ..... it is a dedicated trailer . But ... i tow my Spyder behind my Toyota Corolla with ease . Hard to find a lighter trailer . Just works for me ..
    2009 Roadster SM5 , Silver and Black
    Oct 2015
    Middletown De
    DO you really need a second person to open and close the trailer ? Is there a work around like installing a hoist at the garage ceiling to lift it?
    Sep 2018
    Caledonia,Ontario,Canada
    I us a single rail Stinger with my motorcycles. It tows with out any problems and handles elevated highway speeds. Mine hitches with a bolted pin not a coupler. Folding is a one person endeavour but you need to chock wheels when you unfold it. Keep bearing buddies greased and away you go, your bike is the suspension. Many thousands of miles of use.
    Aug 2018
    Florida
    Quote Originally Posted by dragonridernj View Post
    I have a Stinger that I bought used. You pretty much need two people to lift / fold it. Some say it can be done alone but it's too heavy for one person, at least for me. I've solved the problem by chocking the wheels and using a Warn Pullzall to lift it. Works like a champ and takes only a few minutes to fold / unfold. This method would work for other folding trailers as well. I removed a ceiling vent in my garage, installed a large eye bolt across three rafters (beefed it all up really good) and it lifts with no problem. When finished, I reinstall the vent. Love the Stinger. Light weight and tows great.
    2019 F3 Limited
    Mar 2021
    Ohio
    Any one know if the Stinger trailer will fit a Spyder 20-21 RT?
