Results 1 to 7 of 7
    Active Member Cruising RT's Avatar
    Dec 2014
    United States
    Cool Has anyone towed?
    Has anyone ever pulled, towed a Bushtec Roadstar motorcycle trailer behind a RT? I live in a rual area and the roads are pot-holed and patched, and I've pulled a Can am 622 trailer before and discovered that the Can Am trailer was boucing and bottoming out, therefore scuffing the bottom of trailer so I want to hear anyone's experience with the Bushtec.
    Default BUSHTEC ON BAD ROADS
    Quote Originally Posted by Cruising RT View Post
    I think it's where you are and the speed you are traveling at ..... most small trailers suffer from the same suspension issues because of their light weight...... the ones with rubber torsion axels probably less ( ie the 622 ) ...... jmho .... Mike
    Sep 2012
    Junction City, KS, USA
    with Mike. I've pulled both. Such small and light-weight trailers will bounce around on rough roads. You need to slow down accordingly.
    PrairieSpyder (Patti)
    Very Active Member Jetfixer's Avatar
    Feb 2016
    Lake Wylie, South Carolina, USA
    Also, the 622 suspension is adjustable. It may have been set too light for the load which would allow bottoming.
    2020 RT Limited , Marsala Red
    Dec 2014
    United States
    Cool adjusting
    Quote Originally Posted by Jetfixer View Post
    So what is the process in adjusting the suspension?
    Active Member fjray's Avatar
    Aug 2015
    central oregon
    I pulled A Bushtec turbo+2 for 14k and the trailer was fine. The problem is the way the hitch is mounted on the RT. Being bolted directly to the wheel , all the motion from the swingarm goes into the trailer and ended up breaking the tongue mounts on the Bushtec.
    I fabricated a custom frame mounted hitch and that was the end of All the bouncing and didn't break the bottles in the cooler as before. I took it off when I sold the RT because the only thing that has more liability than a hitch is a ladder and I didn't need the worry. It's in the scrap pile behind the shop now.
    Feb 2016
    The procedure starts on page 16...
    http://www.operatorsguides.brp.com/I...b-5d900561300b
    Select Roadster,
    then Accessories,
    then your year rt-622 user guide
Tags for this Thread
