Results 1 to 15 of 15
    Oct 2011
    Jacksonville,Ar
    15 rt , yes Black
    Invalid Emails
    Rotonda West,FL
    Sorry, this content isn't available right now
    The link you followed may have expired, or the page may only be visible to an audience you're not in.
    Nov 2015
    Myerstown, Pennsylvania
    Here is one that can be had on ebay.
    Amazon has some good stuff too.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Oct 2011
    Jacksonville,Ar
    the link goes to facebook
    15 rt , yes Black
    Invalid Emails
    Rotonda West,FL
    Quote Originally Posted by samewok View Post
    But that link is dead
    Oct 2011
    Jacksonville,Ar
    It works for me maybe you have something turned off.
    15 rt , yes Black
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    link doesn't work for me either.
    I also wanted a "Larson scanner" as they are officially called (after Glen A Larson who used them on not only Night rider, but also Battlestar Galactica (Cylons). The problem I found with the ones offered on Ebay, Amazon etc was that there was a multitude of colors and patterns that the scanner randomly went through. I wanted the "night rider" scanner and in blue ONLY.
    So, after much searching, the only way I made it happen was making it myself with an Arduino. A 5v regulator and the Arduino are in the space to the upper right of the Frunk, and the LED's are across the front of the bike under the headlights (RT-S model) I have a movie of it, but it is at home, and I am at work right now.
    Ray
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Oct 2011
    Jacksonville,Ar
    the new one TricLed has 7 different colors.
    15 rt , yes Black
    Jul 2016
    Kamloops B.C.
    Sorry for the poor quality of the photos and the vid. They were taken by a friend.
    I have the scanner switched by a 5th switch I added to my dash.
    Ray
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    NorCal - Northbay
    And as with anything "light"related and especially on the front, you had better check with your local & state authorities regarding what is legal. I know that won't fly in any way shape or form here in Cali....
    Chuck
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by hypurone View Post
    That's why the switch.
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Oct 2011
    Jacksonville,Ar
    that is why it has a remote to turn it on or off also to change colors
    15 rt , yes Black
    Invalid Emails
    Feb 2016
    Dublin, OH
    Default TricLED night rider
    Quote Originally Posted by bcer960 View Post
    Ray
    Hi Ray, tricled has a custom knight rider LED with 7 different color and blue is one of them.
    White color is included, so you can run it solid as driving light.
    the pattern is not random, we only make to scan only and solid color.
    It comes with RF remote to select color and between 2 pattern, on/off and adjusting speed.
    Here is the link (or copy-paste into your browser) for the night rider.
    For RT Spyder, it will need a "bumspkid" as the bar sits on it.
    https://www.tricledusa.com/_p/prd1/4...ar-with-remote
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by Cindy-TricLED View Post
    Hi Cindy, and thanks for the link.
    Unfortunately the web site does not show it on a RT. And as a person preference, I did not want it low on the bike. When I first saw the Spyder, I said to myself, "this needs a night rider scanner", but up under the lights.
    Does your scanner remember the settings when it is turned off? I.e. I have it on a scanning speed, and blue lights. I turn the bike off and when I turn it back on, the same settings are running?? Or do you have to use the remote to get it back?
    I just wanted a scanner that turned on, and scanned back and forth (with the correct trail of lights) when I wanted it too, not something that took a bunch of work to get to do what I want. This was the problem with the Ebay lights.
    I know I'm being picky, but that why I built my own.
    Ray
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Invalid Emails
    Feb 2016
    Dublin, OH
    Ray
    I understand, nothing wrong of being picky, we want our ride to look a certain way.
    For the RT, we put the bar low on top of bumspkid because the LED bar/strip is long.
    and so far this is the best placement for our night rider.
    RT doesn't have the flat space on the nose like F series does.
