Brp oil
Does anyone know what weight the Brp full synthetic all climate oil is ? And is it ok to use in a 2015 ST 998?
Seeing this is only your 10th post here, the natives MIGHT go easy on ya....BUT, you just opened a can of worms with another "oils" thread. Might I kindly suggest using the "search" tab in the upper right hand corner. If you type in anything oil related, you can read threads for days, weeks, and even months and never get the right answer, or the wrong answer. AS long as you use an oil that meets the specs in your owners manual, life will be good for your spyder. Welcome to S/L
Here's the thing....
If you buy brp oil (XPS) synthetic or blended it works in all model spyders. I believe it is 5W-40. But you can go with other brands and other weights depending on where you ryde and the wheather..
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Any brand that is JASO MA2
2010 RTSM5
What year did they change engines ?
I thought it was 2014.
Ran BRP oil in our 11 RT - 998
The Full Synthetic BRP 5w40 worked well in our Twin 998 SM5 for 76,000 miles, when we traded to the 15 RT. That and Bajarons filter kits kept the motor spinning and miles of smiles coming.
All ST and RS have 998
All F3 have 1330
RT had 998 thru 2013, 1330 from 2014 to present.
Yup! It's a "Triples-only" Club now...
