Page 2 of 2 FirstFirst 12
Results 26 to 40 of 40
  1. #26
    Quote Originally Posted by PW2013STL View Post
    I went to a dealer to purchase the paste and was told that it's a large tube that costs over $100. What the parts guy did was go back into the service area and he put some into a small plastic zip bag (4 changes worth) and gave that to me at no charge.
    Ask your dealer if they will do that for you.
    Cheap Cycle Parts has 90ml of the part number I gave for about $39. That would probably do quite a few plugs.
  2. #27
    Nov 2015
    Myerstown, Pennsylvania
    For anyone interested:
    As you can see, the lower the line is on the graph, the more capable the compound is to transfer heat.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
  3. #28
    Feb 2016
    France
    Default changing spark plugs on 2014 rt limited Your Message
    This paste is also known as "Heat Sink Compound", it's use in tv's with power transistors and chips for the same purpose as BRP are saying, but given the fact that spark plugs are screwed in and tightened, I can't see where metal to metal contact can be improved with this compound, I think it's BRP being OTT like they are with everything else like loctite. The rattling clanking heap of the 1330 engine can hardly be described as quality so I don't know what all the fuss is about. My 1330 runs well but sounds like 2 skeletons tap dancing in a biscuit tin.
    2014 RT Std
    Floor and Highway Boards
    50$ GPS connected to oem loom
    Trunk & Frunk Liners and lights
    Frunk and dashboard power outlets
    Front supension LEDS
    Cup holders
    Glovebox light
    Turn signal LEDs in mirrors
    12 volt coffee maker
    Passenger hangrip muffs
    Ignition lock light
    Windscreen wiper/ baguette holder
    If I wasn't so cleverI wouldn't need to be so good looking.
    2014 RT , Black
  4. #29
    Quote Originally Posted by agedbikeman View Post
    I can't tell if that's better, or worse; than sounding like a tray full of empty dishes getting tossed down the cellar stairs!
  5. #30
    Nov 2015
    Dishes?!! Skeletons!!!?? Where do I find these on the parts listing if they need to be replaced??? How many miles until I have to??
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
  6. #31
    Default THIS THERMAL PASTE
    Quote Originally Posted by SteveLaoyster View Post
    Steve in the upper graff , the box has 7 compounds but the graff only has 6 lines ???? ....... and what exactly is better the ability to transfer heat or the resistance to that ???? .... Mike
  7. #32
    Nov 2015
    I just took a closer look & both the Dow Corning tc5022 and the Shinetsu stuff have the same line. And on the chart it looks like they didn't even bother to put the specs on for the worst of the bunch.
    The ability to transfer the heat from one medium to another is the needed ticket.
    Both the graph and the chart have the ones with less resistance to thermal transfer at the bottom.
    Looks like the Dow Corning tc5022 is the stuff to get. Found it on moddiy.com for $10 for 3.5 grams.
    BajaRon Sway Bar
    Foam Grips
    Shorty antenna
  8. #33
    Yes, the spark plugs are screwed in and you're probably correct that application of thermal paste is not going to improve the metal to metal heat transfer rate. However, there are voids between the treads where there is no direct metal to metal contact at all. It is these voids that the thermal paste fills, effectively creating a much larger contact/surface area through which heat transfer can take place. With the sensitivity of the anti-knock sensors and the related actions which will be taken by the computer to prevent pre-ignition (all negative in respect to engine performance, power and fuel mileage). I'm not sure that BRP is being OTT on this one.
  9. #34
    Feb 2016
    France
    Dishes, Skeletons, AND biscuit tins are all replaced at 30,000 millipigs
    2014 RT Std
    Cup holders
    Glovebox light
    Ignition lock light
    2014 RT , Black
  10. #35
    Feb 2016
    France
    A 25g tube of Servisol heat sink compound which will do all that's expected in this case cost 3.99GBP, about 5 bucks and will do lots of spark plugs
    2014 RT Std
    Cup holders
    Glovebox light
    Ignition lock light
    2014 RT , Black
  11. #36
    BTW the spark plugs are $20 each for a total of $60. My next change will be at 50,000 miles on the current plugs as the ones I changed at 40,000 looked great
    I sell the 3 Spark Plug Replacement Kit for the 1330 motor $36.95 delivered. And it includes Thermal Paste and Dielectric Grease. Don't pay $20 for your spark plugs!
  12. #37
    Active Member lewisalice's Avatar
    Brooklyn NY
    Where is your website so I can order from you?
  13. #38
    Feb 2012
    Spring City,Utah
    agedbikeman:" My 1330 runs well but sounds like 2 skeletons tap dancing in a biscuit tin".
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
  14. #39
    Quote Originally Posted by lewisalice View Post
    email me at fyredad@hotmail.com
    or PM me here on Spyderlovers.com
  15. #40
    wisconsin
    So what's the rumor I've heard that, it's easier to take the frunk off to get to the plugs??? Mac
