Results 1 to 25 of 25
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    Question stubby antenna removal 2014 RT LTD
    Good morning everyone. Well I've read alot that the stock antenna on the 2014 RT can be tough to remove. I think mine is stock. It was on it when I bought it last year. I've watched a couple of videos and read on Big Bikes that you should make sure you can get it off before buying the shorter antenna. Well mine had marks on it like someone messed with it before but I got it off with a pair of needle nose vicegrips but I sounded like a nut on the bottom inside fell off when it came off. Is there a nut from the bottom to hold it on?
    Thanks, Mike
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    No... The antenna (Any of them) screws into the base. the cabling that connects it to the radio, hooks in from the other side.
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    A 7mm open ended wrench should remove the stock antenna.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    That's what I used to remove mine.
    A 7mm deep-well socket.
    (I grabbed it with a set of Vise-Grips.
    Nov 2015
    Tinley Park, Il
    Okay, when you have a radio antenna and a cb antenna isn't the radio on the dravers left. That one is about a 13mm and the one on the right looks like a 7mm but I thought that was the cb. When I removed the left one it sounded like a nut fell down inside. I've never had a cb so if I want to use it what do I need to do (local/state laws) and what can it do for me? Thanks, Mike
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    Quote Originally Posted by wmh9680 View Post
    When standing at the rear facing forward (this should be the same left and right as you describe) the radio antenna is on the right.
    Nov 2015
    Tinley Park, Il
    Duh, ya can't fix stupid. I realized that after looking at some pics and videos. I now wonder what dropped inside when I removed the cb antenna. Thanks, Mike
    Nov 2015
    Tinley Park, Il
    Hi, Just received my stubby antenna, hope to put it on today.
    Vermont
    Use a 7mm deep socket wrench w/extension. I have a 2014RTS-SE6. My original antenna broke off, I replaced my own with a shorty, antenna/ boot. Here are some pictures: New Radio Antenna on 2014RTS-SE6 003.jpg New Radio Antenna on 2014RTS-SE6 002.jpg New Radio Antenna on 2014RTS-SE6 001.jpg Sorry I don't have any pictures of the base ( inside) where the antenna connects. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Nov 2015
    Tinley Park, Il
    Thanks everyone. I got the antenna on (I did not use locktight yet) and it works. I noticed that on AM 67 (the Cub's station) I get a whine on the station and it does not seem to be there on any fm or other am staions. It also gets some static on that station. We gotta do some more riding to check it out. Any ideas. Thanks, Mike
    Active Member dslim's Avatar
    Rice MN
    I wonder if the reception is any better or worse with the short antenna. I just got back from a 3800 mile trip, I lose a radio station every 5-10 minutes on my 2014 RTS. I'm glad my iPod works, but I think I'm gonna have to invest in satellite radio.
    Aug 2013
    St Petersburg, FL
    Yep, it's true. A 7MM socket will remove the old antenna. Now what? I saw on another post that the 2013 and earlier models had their antennas in there really tight, and they were right. Guess I'll be ordering another part before I order a shorty antenna.
    Reception on the radios leaves a bit to be desired. We have the radios on both our RT's--and hardly ever use them. There are a couple scenic rides where we like to listen to country tunes--the only station we can get in our rural area. Long or short antenna does not make a difference for us. Mountain ranges make a difference--and we have a lot of them in our area.
    Aug 2013
    St Petersburg, FL
    Doesn't matter to us either, and it's the wife's bike. But now there's a hole I have to fix or maybe I'll just plug it
    Active Member R FUN's Avatar
    Apr 2013
    Rocanville Saskatchewan canada
    My antenna broke off also. Tried a shorty and very poor reception, Rethreaded an auto antenna, they are the same leangth as original and it works great,
    Roger
    2012 RT Limited
    Vertika Floor boards
    Painted rear fender & dash
    Carbon fiber panels
    Utopia back rest
    Baker air wings
    Elka shocks and relocaters
    CB radio
    ISO hand grips
    Tric LED fender light
    Turn signal lights in mirrors
    Quote Originally Posted by FiFi View Post
    If you can't get a plug for that hole order one for the other side, the CB antenna hole. If I remember right it'll work but you'll have to modify the tabs to fit. Left and right plugs are different.
    Vermont
    that is what I used ( 7mm deep socket wrench) Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Feb 2017
    Houma, Louisiana
    Will the 7mm socket work on my 2106 RT Special?
    2016 RT-S Special Series
    Spyderpops LED Bumpskid
    LED headlights and fog lights
    Nov 2017
    San Francisco Bay area
    Bumping this as I rode my bike to work and when I went to put the cover on I realized the antenna and boot were missing! I don't know if it fell off or someone took it but since I wanted to put on a shorty or plug it altogether I'm wondering if anyone has an antenna recommendation at this point. I don't use the radio as opposed to the Sena and phone connection for music etc. If I plug it anyone know where I can get one? Pearl White 15 RTL. Feel free to tell me to do some research, I've done absolutely none having just arrived at work.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    2015 RTL , Yes Pearl White
    Active Member Raprider's Avatar
    Oct 2017
    Central NJ
    I've not replaced mine, but I did have this bookmarked from an earlier post...
    https://www.walmart.com/ip/Scosche-R...&wl13=&veh=sem
    Raprider (Rich)
    2016 Can-Am Spyder ST-S SE5 Steel Black Metallic (Blackbird)
    BRP Audio, Heated Grips, Fog Lights, Passenger Backrest, Givi Saddlebags/Top Case
    BajaRon Swaybar, TricLed Wide-Vu Mirrors, Lamonster Ram mount and X-grip, Sena 20S Evo Dual
    TricLed Sequential Front SpyderFenderz, Dual Color Run/Brake/Turn LEDs, Brake Flasher
    Kumho Ecsta AST installed on rear 4/2021
    1996 Yamaha Virago 750 (Vera) - still riding
    1987 Honda Shadow 500 (Shady) - sold
    1982 Honda Rebel 250 (Little Reb) - sold
    Nov 2017
    Here’s a pic of what’s left
    Baja Ron Sway Bar
    Strobe Brake Light
    Dec 2015
    NE Ohio
    Quote Originally Posted by Bayouboy View Post
    No sure since I have not been able to get mine off. I think you have to cut the boot off so you can get to the nut. Some say to twist the antenna until it breaks and then you can get to the nut. I have not been able to snap mine by twisting with pliers. If you have better luck, tell us how you did it.
    Nov 2017
    My boot looks like it just rotated under the metal flanges. It obviously came off pretty easily once it was ready.
    Baja Ron Sway Bar
    Strobe Brake Light
    Active Member Sarge's Avatar
    Yanceyville,NC
    When it comes to antennas, size is king. Optimum 1/4 wave for FM is 31-inches and you will be hard pressed to find one that long to fit your Spyder. You can forget about this as for a 1/4 wave AM antenna at 1000kHz would be 234-feet long! As far as CB radio is concerned, you will have to go with the factory BRP CB antenna or something similar. Probably a wound or coiled whip. Remember ... 1/4 wave CB antennas are 109-inches long! I've just found that my factory AM/FM antenna spins freely in its mount, SO ... I'm gonna have to look into this myself. N2YVK 73's
    Ride Safe.
    Shoot Straight.
    Speak the Truth.
    David & Deb Parsons
    "Sarge"
    2015 Circuit Yellow Spyder RT Limited
    2010 Velocity Yellow Kawasaki VN1700 Voyager
    AMSOIL
    AMA Member
    AVA Member
    VROC Member
    KawaNOW Member
    Patriot Guard Rider
    US Army M.I., Retired
    NRA Instructor & N.C. CCW Instructor
    Never mind Area51. Worry about the other 50, or more!
    2015 RT Limited , Circuit Yellow
    Vermont
    Quote Originally Posted by OverHillAndDale View Post
    Also, use a 7mm deep socket wrench.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
