Results 1 to 20 of 20
    Aug 2016
    Calverton N.Y.
    Default 1 gear not engaging
    2013 SE5 4400 miles When taking off in 1st gear , starting to happen more often, it does not fully engage. There is a noise, sounds like a machine gun, then once the bike starts to move a little it engages and takes off.
    Any ideas about what can be happening? Like to have this fixed before we leave for our trip in july.
    Jun 2010
    Las Vegas
    What year is your RT?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Apr 2017
    North Central Florida
    And what transmission, manual or auto ??
    Default Depends....
    Could be gears but more likely the clutch. Gears would mean no movement and just grinding clutch is more noises but once engaged you can roll on. Semi auto will be more likely to have this problem the manual you will know because you control the clutch operation.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member rcturner's Avatar
    Jun 2012
    Fairmont, Minnesota
    It sounds as if clutch failure is imminent. Could be in the clutch hydraulic system but in any case you need to get it addressed before any other damage happens.
    Aug 2016
    Calverton N.Y.
    2013 SE5 Helps right LOL
    Aug 2016
    Calverton N.Y.
    Quote Originally Posted by rcturner View Post
    Would this be something I can fix myself?
    Aug 2016
    Calverton N.Y.
    Thank you. SE5
    Aug 2016
    Calverton N.Y.
    2013 SE5
    Aug 2016
    Calverton N.Y.
    2013 SE5
    Jun 2012
    Fairmont, Minnesota
    Quote Originally Posted by Rawspyder View Post
    Probably not unless you have any special tools required and a lot of experience with this type of clutch system.
    Aug 2016
    Calverton N.Y.
    [QUOTE=rcturner;1265220]Probably not unless you have any special tools required and a lot of experience with this type of clutch system.[/E]
    Ok Thanks for your input. Will keep you posted with what happens next.
    Aug 2016
    Calverton N.Y.
    Today I took my bike for a ride. Had no problem with 1st gear engaging. Ran great. Not sure what to do next. Called my dealer. They never serviced a clutch before. Yikes.
    Any thoughts?
    Active Member Lobo's Avatar
    May 2016
    Murrels Inlet, South Carolina
    When this happened on my 2012 RT, the dealer reset the TPS. The problem went away. That was 10,000 miles ago.
    Aug 2016
    Calverton N.Y.
    Quote Originally Posted by Leatherneck View Post
    Thanks for your suggestion. I will bring the Throttle position sensor issue up with my dealer. Safe riding.
    You may be experiencing a known clutch issue. See this thread and the link to another thread contained in it.
    http://www.spyderlovers.com/forums/s...clutch+shudder
    Mar 2014
    Alice Springs, Australia
    Did you ever get a satisfactory result re your issues, and what was the problem? After completing a ride recently, my 2011 RSS SE5 has the same issues, and as the nearest Can Am dealer is 950 miles away, I would like to get some idea where to start looking to resolve the problem.
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    Just a thought. I always let my SE5 warm up to three bars before putting it in gear. Really doesn't take that long. I'll do a walk around, put my riding gear on while it's warming up. It still clanks when shifting into gear the first time, but never shutters on throttle up. Oh, and I have the new clutch design too. jm2c
    Mar 2014
    In my case described above, I just returned from a 175 mile ride, pulled into the service station to refuel and the noise appeared when trying to take off.
    My bike has only ever seen 3 bars a couple of years ago on a cold winters day, the rest of the time, normal operating is 5 bars.
    Feb 2012
    Spring City,Utah
    Quote Originally Posted by Jeriatric View Post
    I have found if I let my idle speed settle down after starting it will go into gear much quieter.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
