No longer a virgin!
Finally overcame my fear of stripping the bodywork off my RT. I did so to install the BRP belt Tensioner. The install went great and the results were tremendous even thou I hadn't realized a problem, the bike uses to rumble aa bit at highway speeds.....now that is gone completely.
As an aside....I was surprised at the amount of dirt under the body panels. I am wondering if others remove the panels just to clean the undercarriage?
Ayway all good even the feared mirror removal and replacement went great.
Cheers and Ride Safe!
belt
belt--
Originally Posted by mike1952
which
The Brp one....with the Doc Humphrey's adaptor plate.
Live, Love, and Ride! God Bless!
Congrats. ..
Not as bad as you thought..🤔 I do remove them all and do a frame and engine clean once a year...
It seems the first time you have to remove panels is always the hardest. You read the manual about 10 times and still aren't sure if you are doing it right. But it will be easier each time you have to do it from now on, and take very little time too.
after being alone for so long, i am now a born again virgin
Ditto!
While cleaning it is a good time to check wiring and insulation, just annual house keeping under the skirts.
Joe
Nice, I'm going to take apart too soon, waiting on parts. GPS, USB connections, horn and radar detector.
