Results 1 to 17 of 17
    Active Member Pat Clark's Avatar
    Oct 2015
    Woodbine, Ga
    Default Pictures showing rotated 90° - Why? Any fix?
    I must be more computer stupid than I thought. When I post pictures on FB of my bike they come out fine. When I try to post them here they are rotated 90 degrees. Can't figure this out.
    Any help?
    Pat
    Jun 2014
    People's Republic of NY
    Are they taken with a I device?
    committee for postings
    Oct 2015
    Woodbine, Ga
    Finally figured it out... I think. Computer was rotating the pics from my phone and took me a while to square away the computer
    I take all my snapshots with the phone these days.
    Pat
    SIGPIC]2
    2016 F3T Lamonster RIP boards, fog lights, Longhorn mirror lights, power plate. SpyderPops skid plate. Painted the silver air intake and grill.
    If you happen to post one, and it's sideways: just ask, and somebody will spin it around a bit for you!
    Oct 2015
    Woodbine, Ga
    Thanks,Pat
    SIGPIC]2
    Dec 2015
    Oakley Utah
    Default How to get correct orientation on posted pictures?
    How to ask? I've got several pics on one of my posts that have the wrong orientation.
    2014 RTL Platinum
    Dec 2015
    Oakley Utah
    http://www.spyderlovers.com/forums/s...el-on-RT/page2 #34
    2014 RTL Platinum
    Active Member Slowpoke387's Avatar
    Apr 2017
    Enfield, CT
    If ur using an iphone you need to take them with the phone horizontally and the home button to the right. Landscape mode. Should solve all ur problems. If you have an android ur on ur own lol.
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    I have found that for this site when getting pics from my phone, I take them larger than needed, then crop about 20% and they appear just fine.
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
    Dec 2015
    Oakley Utah
    Default How to change the displayed orientation of posted portrait orientation pics?
    Quote Originally Posted by Slowpoke387 View Post
    You are right in that the default orientation on this forum seems to be horizontal (landscape). Any pics that were taken in portrait orientation appear 90 degrees off. It doesn't matter what camera (or smart phone) you use. Someone on this post seems to be a moderator and indicated that they have the ability to 'fix' this issue after the fact if they are asked to. Problem is, they didn't say how to ask to have it done.
    2014 RTL Platinum
    If you need to ask to get your pics 'rotated', just post it up in the thread; simply say it plainly in a post - for example, you coud post something like the following:
    "Damn, all my pics are sideways! Can someone who knows how please rotate them for me?"
    It works, every time! Might take a while, but it does work.
    Dec 2015
    Oakley Utah
    Okay, so I need my pics rotated please;How to ask? I've got several pics on one of my posts that have the wrong orientation.
    2014 RTL Platinum
    Sorry Utah, I should've been clear in my previous post - it might be best to put that 'ask' in your thread, maybe even edit one of the posts with a sideways pic in it and put the question in there.
    Generally, if you ask for them to be fixed in the thread where the sideways pics appear in one of the posts, then someone will cotton on & fix them for you! Or you could follow the 'ask an admin' links, or even the 'View Site Leaders' link in 'Quick Links' in the menu bar at the top of the page, & send one of the Admins or Site Leaders a PM.
    Good Luck!
    Failing all of the above, you could also open your pic in just about any picture editor & rotate it to the orientation you prefer before posting it up here - it might take a bit more effort, sure, but it means your pics will ALWAYS appear the way YOU want them too, instead of in the default display mode for the device that took them.
    Dec 2015
    Oakley Utah
    I'll play around with that. Thanks.
    2014 RTL Platinum
    Default Why...
    Your taking all the fun out of viewing them. Have you ever watched as they turn the tablet or phone the picture turns too till they set it down and walk around it..
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Active Member fetermel's Avatar
    Jan 2016
    MN.
    Default Pics
    I have found that if you edit and shrink your pictures just a little bit before you attach them they will come out just fine every time.
    2013 STS , OEM Circuit Yellow
