Results 1 to 23 of 23
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    Default My newest farkle and maybe the last
    Well, it has taken a while, but I think I've run out of things I've wanted to add to my RT, but, I have to say the wheel balancers that Lamonster Garage has look interestin.
    I hope this video works:
    David
    How old would you be if you didn't know how old you were?
    Did I hear you correctly?
    What is a "Last Farkle"?
    I've been told that the process NEVER stops...
    (At least not until you run out of money! )
    Oct 2015
    N.E. Florida
    Well Bob, there are a couple of things I still don't have, a trailer, the wheel balancer I mentioned, but not much really. I think I'd like and F3, but as long as my wife is my riding partner I won't get rid of the RT. For my money, it is the best trike for riding two up. So now all I need to do is put gas in it, (gas isn't a farkle is it?), and ride, ride, ride.....................
    David
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    last farkle--as elusive as bigfoot.
    i seem to be a member of the farkle[or 2] of the month club
    STOP MAKING NEW STUFF !, people.
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
    Active Member 11rtLTD's Avatar
    Mar 2017
    ICT
    Default F3 LTD
    Quote Originally Posted by Devious56 View Post
    David
    This should make both you and your wife happy!
    https://can-am.brp.com/spyder/2017-m...3-limited.html
    2011 RT limited , BajaRon plugs and custom wires Pearl white
    Active Member BernardD's Avatar
    Mar 2017
    Geneva, Switzerland
    Thumbs up
    Hi David ... greeting from Switzerland.
    very nice. Thanks for sharing.
    I have the voltmeter gauge but an analogue clock.
    I think that you did set this up in a very nice way and uniform (same kind of gauges).
    Now mine are not installed yet and I may consider changing my clock for the one you habe but some question for you ...
    I noticed that you have the animation of the gauge when you turn off the key. That means both gauges are permanently connnected to your battery also.
    - is this taking a lot of you battery?
    I am afraid that if I setup mine like this, not using my Spyder everyday and not connecting a battery tender, this may drain my battery.
    any feedback from you on this?
    Thanks in advance and thanks for sharing this (but I am convinced that those are NOT your last Farkles).
    kind regards,
    Bernard
    And congrat for your work!
    Last farkle? I am also thinking a dubious situation. I have been done for at least two years, but recently found the stick on full size mirrors from TricLed. Two sets on the way for the 11 and the 14. I am thinking these should be the "last" farkles.
    Vermont
    David
    I think that dashboard needs some color!
    Take a look @ my post's or My Albums you'll see what I mean.
    Several other people have painted there dashboards, on this site.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Oct 2015
    N.E. Florida
    Quote Originally Posted by 11rtLTD View Post
    Not on your life! My wife sat on that rear seat and said no way. I sat on that rear seat and would recommend it to anyone. Feels like sitting on a bump. Don't get me wrong, if I was getting a bike for me, it would be an F3, but I'm talking about accessories, not a new trike.
    David
    Oct 2015
    N.E. Florida
    Deanna
    Glad to see you every once in a while, missed your posts. I remember when you did your dash, and thought it was really nice. Since my RT is black, I think I'll leave the dash black.
    David
    Oct 2015
    N.E. Florida
    Quote Originally Posted by BernardD View Post
    kind regards,
    Bernard
    Hey BernardD, good point, and yes the animation calls for a constant 12 volt source, but the clock would require a constant voltage source anyway in order to keep constant time. I don't think that actually draws down the battery much, but I don't leave my RT sitting around idle too much, I ride a good bit most of the time, and , when I'm not riding, the Battery Tender is connected. But, I did buy one of those jump boxes that Lamonster Garage sells and can not jump start the Spyder if needed.
    David
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    Default Nice job!
    David
    Hi I have the same voltage guage but have never seen that clock! Where did you get it? I would like to replace the one I currently have with one like yours!
    14 RT-S , Stock Large brake pedal White Pearl
    Oct 2015
    N.E. Florida
    Quote Originally Posted by NM Wrench View Post
    Prosportgauges.com, PSCLKCD-12H
    David
    Vermont
    David
    David, I still post/and start threads on this site. Just look @ my posts Count #'s. It seams like yesterday when I posted pictures my painted dashboard. To each his own, about the dashboard.
    I have 17,000+ miles on my 2014RTS-SE6. It only took 3 years to get to my current mileage. I have put on a lot of farkles, 2 new front tires, ( last year) 1 rear tire( General Altimax RT43, which I have a lot of thread left. )Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Newton, N.C.
    David
    Are these gauges plug'n'play? What are the part numbers for the ones you installed, please?
    Great job.
    Oct 2015
    N.E. Florida
    Quote Originally Posted by SmokenJoe View Post
    Great job.
    Joe, post #13 has the info for the clock, the voltmeter is PSVOLCD-NEW. The gauges come from prosportgauges.com
    When we got our 2014 RT-Limited: I have to admit that some of my selling points were a bit...
    creative?
    Active Member LateLifeCrisis's Avatar
    Oct 2016
    Maryland
    Hey Bob....wasn't I the one who told you, "When Pigs Fly?" (Love the new avatar, by the way!!!)
    He's on his RT She's on her F3
    And the Keys to a Happy Marriage: Separate
    Bathrooms, Individual Remote TV Clickers, and
    His and Her Spyders.
    "If there are no dogs in heaven, then when I die,
    I want to go where they went." ~ ~ Will Rogers
    "Never in the field of human conflict was so much owed by so many to so few."
    ~ ~ Winston Churchill in his tribute to the RAF.
    "I'd like to know why well-educated idiots keep apologizing for lazy and complaining
    people who think the world owes them a living." ~ ~ John Wayne
    GOS 3799
    Newton, N.C.
    are these plug n play? If not are the directions any good?
    Quote Originally Posted by LateLifeCrisis View Post
    Yes; you were...
    Oct 2015
    N.E. Florida
    Pretty much, you need a constant 12 volt, and a switched 12 volt, plus a ground, for each guage.
    David
    Newton, N.C.
    Thank you.
    Oct 2015
    N.E. Florida
    Thank you.
    My pleasure.
