Results 1 to 19 of 19
    Active Member Buckeye Chuck 54's Avatar
    Jun 2015
    Zanesville Ohio
    Default Oil Drain Plugs - Dimple or Gold?
    My last oil change I stripped the torx head on the transmission plug. I've read some comments of replacements here. What do you recommend?
    And how can I get the bad plug out? There may be enough shoulder to get a vise grip on it. I hate to pay the dealer $85 to do the job.
    Buckeye Chuck
    Default VS.
    Back a few months ago some people here had issues with the Dimple brand failing ..... it appeared the thread area was too thin after they drilled for the magnet ....... So far no issues with the Gold brand ...... Mike
    Default Choices, choices
    You will get many opinions so with no explanation....I use dimple..
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default If just getting the one plug- Check Lamonsters Site for a ShowChrome Plug
    Quote Originally Posted by Buckeye Chuck 54 View Post
    Buckeye Chuck
    -I'm not sure if the transplug is a 12 or 14 mm- Lamonsters site showed some magnetic plugs with a Hex head.
    2015 RT , OEM Black Gloss
    Mar 2013
    Marion, Arkansas
    When I first switched from the OEM plugs I went with Dimple plugs.. Then I heard that a few were having issues with the Dimple brand and at my next oil change switch to the Gold plugs. I switched to the Gold plugs just for peace of mind. I had no problem with the Dimple plugs though.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    You don't say what model Spyder you have but if it's a 1330 engine, the transmission (actually clutch cover) plug is a 6mm Allen, not a Torx. You might consider trying to grind down a larger, like 7mm Allen, and tapping it into the plug to remove same. I've had no problem with my Dimple plugs.
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Buckeye Chuck
    Had a friend with one stripped on the oil tank. Got me a big pair of channel locks and was able to break it loose. I got a set of gold plugs ready to install at next oil change. I have used Gold plugs in the past with no problems. Cannot say anything bad about Dimple , have never used them.
    David
    Jul 2016
    australia
    i use the dimples in my 1330.i think you can break anything if you try hard enough.
    to get the old one out try looking for a kit called spline out,we have them here in aus.you knock them in with a hammer and they cut their way into the part left.put a spanner on and bingo you got it.
    ive tried a larger torx bit with socket head banged in too,it cuts in nearly as good.
    stu
    Very Active Member Bam Bam and Pebbles's Avatar
    Nov 2014
    Rural Hall NC
    I have used the Gold plugs in both my Spyders. MP-01 and MP-18 are the plugs you need for the 1330 engine and MP-01 is used on the 998's.
    Current Ride
    2015 RT-S SM6 Cocaine
    Pearl White
    Diamond R Web Armrests
    Shorty Windshield
    Previous Ride
    2012 RT SM5 The Beast
    Pure Magnesium Metallic
    Gold here...
    Houston
    The hex head replacement plugs are fine on the trans side if you really think you need them. On the engine side with the 2 orings and the treads at the far end of the plug, we will not install the aftermarket plugs that have been drilled for a magnet. Leaves far too weak of a plug body under the o-ring grooves. Its a MAJOR operation to get the broken off plug out when it breaks.
    Use the correct tools on the factory plugs and you will not have any problems with them.
    And for the OP, the trans plug is 6mm hex, not torx. You may not have stripped it at all. If you did, its because you stuck the wrong tool in it.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Apr 2016
    Lancaster, PA
    Buckeye Chuck
    BOTH OE PLUGS STRIPPED ON ME LAST TIME SO I GOT THEM OUT WITH A GOOD PAIR OF VISE GRIPS ON THE LIP OF THE HEADS, NO PROBLEM.
    I PUT GOLD IN AND LOVE THEM!
    Apr 2011
    GREENVILLE, SC
    Default GOLD
    GOLD
    http://goldplug.com/
    888-578-3851 ask for Tim...
    Dan P
    SPYD3R
    Nov 2012
    North Las Vegas, NV
    Dimple, I have had them on all my bikes.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Active Member spyderryder53's Avatar
    Hanover CT
    Default gold
    Buckeye Chuck
    the very first time I used the dimple plugs the clutch cover plug broke in half that oil change cost me $800 + I put the factory plug back in and just make sure I tap it a little to seat it all the way in and it won`t strip if a quality bit is used.
    Leon
    2022 marsala red RTL
    AND
    2014 RT S SE-6 COGNAC, 2010 RT 622 TRAILER TIMELESS BLACK
    BRP trailer hitch, Utopia back rest, Baja Ron sway bar , heim links. Elka stage 2 shocks front and rear.
    TricLed fender lights, saddlebag lights and mirror lights. LED headlights and fog lights, Wide vu mirrors.
    spyderpops LED bumpskid ,zippered cargo bag linings, Laser Alignment by Netzleys Tire, Stebal air horn
    stant gas cap,( Dimple oil plugs REMOVED ) JT dash mount.
    (Onboard) Lamonster Garage air compressor and intelliboost charger.
    May 2013
    Edmonton Alberta, Canada
    I've used Dimple plugs since they have been available in my 1330.
    I've had no trouble with these plugs at all.
    With a tork rating of 15 foot pounds for the drain plugs can't see ever having a problem with these plugs if installed properly...
    2014 RT-Ltd , Cognac
    Jun 2022
    N.E. Fl
    Apparently Gold Plug has folded, the phone is disconnected and e-mails etc... go unanswered. Placed an order and funds were paid...crickets
    2016 F3-T , Blk/Rd
    Dec 2015
    Oakley Utah
    Quote Originally Posted by Jane1330 View Post
    I wonder if their decision to accept crypto had anything to do with it? https://goldplug.com/blog/
    2014 RTL Platinum
    C'mon people, the resurgence of all these oil change & drain plug threads is simply because Jane has (in every thread) kindly given us a heads up that apparently Gold Plugs has folded!! See post #17, quoted below....
    So there is no further need to rehash the already finalised discussion in any of these threads - not unless you've got something new &/or helpful to add that hasn't already been covered, anyway!!
    And No, there is no need to report these posts, it's not spam - well, not yet anyway!
