Results 1 to 15 of 15
    Apr 2017
    So Calif.
    Default Reading the owners manual
    I am reading the owners manual, and I noticed one odd sentence, who knows there may be more!
    This is for shifting out of reverse on an RT SE6.
    To shift out of reverse, stop vehicle and push on upshift selector quickly to shift into neutral and more longer to shift in
    first gear.
    It must have been the result of the Indonesians, who were translating the manuals into English...
    Actually it seems to be true. While holding the selector down, a quicker action on the shifter will bring it to neutral. A longer action on the paddle will put it in first.
    Active Member Hokiev's Avatar
    Jun 2011
    Indian Land, SC (30 miles S of Charlotte, NC) was Spotsylvania, VA
    That's just a MORE BETTER way of stating the same thing
    HokieV
    2015 RTS Intense Red Pearl (New Jan. 2016) - Comfort Heated Seat w/Backrest, Custom Dynamics HMT Brake Light, superbrightled.com Brake Light Strobe, TricLED fender lights w/Blinker Module & Turn Signal Strips, Stebel Nautilus Horn, FOBO TPMS, Spydercuff, Dual USB outlet, Bike Barn.
    Previous - 2011 RT Limited.
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    Quote Originally Posted by Flyboyron View Post
    first gear.
    If you push the button & it works that's all that matters. Ryde safe!!
    AKA Jud Smales, Four Year Spyder Ryder!
    "Quando Omni Flunkus, Moritati"
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Driver & Passenger Gel Pads in Seat
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Break Stripe Kit from Wrap My Spyder
    2016 RT-S , stock not yet Pearl White
    Jun 2010
    Las Vegas
    Congratulations on reading the manual so many people don't bother.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jul 2014
    Mint Hill, NC
    Quote Originally Posted by SpyderAnn01 View Post
    The new American motto is, "Why bother to read the owner's manual when you can ask a question on the internet!"
    End of rant.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Quote Originally Posted by Hokiev View Post
    Be careful: Are you referring to "more gooder"; or "more better"?
    There is a subtle difference between the two of them, and I'm not sure if one is actually "gooder', or "better", that the other!
    Apr 2017
    So Calif.
    The proper terminology is "More better", or "Less Worse".
    That may depend on what part of the Country you live in...
    Around here: it has been largely replaced by this:
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    Residing very close to the W. PA line I believe that it should be "more gooder" or perhaps the most extreme, "Most goodest".
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
    Very Active Member rcturner's Avatar
    Jun 2012
    Fairmont, Minnesota
    End of rant.
    The great thing about this approach is that your answer is potentially a useless or dangerous collection of "internet wisdom". Another case where you really need to have some idea what the real answer should be before you put any credence in the answers you receive. This holds especially true when technical information is requested.
    Which brings us to "Mudd's Paradox"...
    What do you believe, and when is it safe to believe it?
    Idaho
    Hey guys, give Flyboyron a break! He's new here so probably is not familiar with all the jabs and ribs a posting like this will elicit.
    Actually, he is pointing out a common problem in translations. Keep in mind the first language in Quebec is French, and they probably do the majority of work at BRP using French, including writing manuals. The person who did the translation is probably not expert in American English, and such phrases as "more longer" are the result. I don't know diddly about French language, but those of you who do can maybe tell me if the French sentence structure might actually be "more longer" when translated literally.
    You see some really odd stuff in English manuals that are written by Chinese.
    2014 Copper RTS
