for those so inclined
And they seem to fit for both the rider and passenger positions equally-well!
The Missus sits on one of them... I just snuggle down into the sheepskin seat cover...
But I DO think that they should offer a "Whoopie Cushion" option!
Personally not my thing, but, I wasn't surprised to learn of: https://www.amazon.com/Motorcycle-Sp.../dp/B00NZF8GTE
coming from the wild side of the two wheeled world.
2016 RT-S Pearl White
BRP Driver Backrest
Lamonster Spyderdock, (2) Spydercuffs
Magic Mirror w/Doc Humphreys tethers
(2) Rokform phone mounts
FOBO
SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
Lamonster LED headlights & foglights
Spyder Pockets
LED front fender kit -running & turn signals
Custom Back off mudflap
Vinyl nameplate & 1330 triple decals by New Image Signs
Custom RLS exhaust
Hogtunes speakers 5 1/4 front and back
Memphis Powersports Amp
Her name is " Purl"
Originally Posted by Kredab
First ride was interesting, I thought I had to much air in it, I was rolling over the top of it, almost let all the air out, it was much better. Seems like you want to run very little air in it .
Yep, that's exactly right, Kredab. Several others have posted earlier in the thread about the need to run it with minimal air. That effectively makes it operate like a poor man's Russell Daylong, where the seat wings curve up to support the outer thighs. With all your centre weight on the Airhawk, that forces any remaining air out and up providing that same outer thigh support....that's the way it was described to me by the Aussie distributor.
Pete
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
I have a Corbin Lamonster cut and the Airhawk is like a custom match for it. The Lamonster has extra padding scooped out and the Airhawk fills in the gap. Tip: criss-cross the straps under the seat to give a better fit, also let the valve stem stick out the side and over inflate it. sit on it and slowly let the air out till it feels right. I also love the way the air re-distributes when you lean to aid in your twistie madness.
2017 F3 Limited
go purple
Originally Posted by oldguyinCT
Have had the Airhawk for 3 years, can't imagine riding without it. And, as mentioned before, you sit in it, not on it.
my old tail bone
I installed the Airhawk R today, and it cures the monkey butt as advertised. But I like to drive my F3 Limited to the limits, and I am finding the Airhawk very instable, and it gives a rollover slide at inconvenient points in the turn. Am I doing something wrong? The raised center of gravity is also noticeable. I did not run it full but not flat either... I feel like less air would make it even more prone to movement. There is just a lot of ways for the top surface to move over the inner surface which can move relative to the bottom surface touching the seat. It really makes me lose all confidence in turns, like I am losing road feel, and the mid-turn shift can really give the machine a jossle. I am 5'10" 200 lbs. by the way, not the lightest or the heaviest with average length limbs. Otherwise the Airhawk delivers to correct the seat position and long term comfort
Use a medium cruiser Airhawk. Site in it, inflate then adjust while on it!
You have too much air if you get a rollover feeling
2015 an Am Spyder RT Limited
2013 Yamaha WR250R - Sold
2011 Can Am Spyder RT-S SE5 Limited - Sold
2011 Aspen Sentry Trailer
2003 BMW K1200LT - Sold
2007 Unigo Trailer - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 NightHawk - sold
2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
As bmwlarry says, they need to be run with minimal air pressure. The Airhawk works along the principles of Russel Daylong, where the raised wing on the side of the seat supports the outer thigh. Your bottom should be effectively touching the seat, which squeezes the air in the airhawk out to the sides, thus supporting your outer thighs. That’s the Daylong principle also for longer term comfort.
Pete
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
Thanks everyone, I had read this thread but somehow missed the key post about this... I was running with low air, but I can see that it should be even lower. I will try that today and if not, MotorcycleDave's I think would work for me. The idea of the medium is intriguing too, if I have a small butt
