Results 1 to 16 of 16
    Active Member bobgeorge's Avatar
    Jun 2015
    Georgetown, KY
    Default Listening to my Ipod/Phone music through my Spyder Speakers?
    Hello,
    I have a 2015 RT Limited. It is possible to listen to music from my iPod or phone through my spyder speakers? If so, how do you do it?
    Thank you!
    2015 Can-Am RT Limited Pearl White
    Farkle: Laser alignment, Bararon sway bar, Bump skid with LED, Tri Axis adjustable handlebar, BRP heated comfort seat, Utopia backrest, Kott grills, Tailgunner Black Widow exhaust, BRP adjustable side wind deflectors, and Upper wind deflectors.
    Dec 2015
    south jersey
    Post
    if you bought it new there should have been a cable in the back, it worked for my friends phone but I had a I phone so it didn't work. there is a adapter you can buy for it.
    Bossier LoUiSiAna
    Your limited should have come with the 30 pin ipod cable & if you have the apple lighting adapter attached. The cable plugs int to a port I think The RT has one in the trunk
    The rest is controlled thru the mode button & radio.
    https://youtu.be/eqf6LOVsS2k
    there should also be a cable with a 3.5mm aux headphone jack that will play music but not allow control to skip or search.
    Active Member Border Rider's Avatar
    Aug 2015
    Derby Line Vermont
    Default listening to Ipod
    I have a 2016 RTS that came with a ups connector on the cable in the rear trunk. I have an Ipod Nano so I just use my apple
    cable that came with it. Can control it from the mode switch. On my 2011RT I purchased an Apple 30 pin to lightning pin
    addapter.
    Very Active Member Buckeye Bleau's Avatar
    Aug 2015
    Canton, Ohio
    Your bykes are newer than mine, but in the trunk on the left side there I should the traditional cigarette style charging port, on the right there is a different port. Mine came with two cables, one is for Apple and the other is a multi pin connector that can be used on most any other device, Sony, Android, etc.
    Then you cycle through the mod button to input for audio to locate the port,and you are good to go.
    Joe
    U.S. Army Viet Nam Era Vet
    Utopia Deluxe driver backrest
    LED fender lighting
    Fast Flash LED brake light
    Spyder Pops LED/skid plate
    Very Active Member Bam Bam and Pebbles's Avatar
    Nov 2014
    Rural Hall NC
    On my bike, I start it, hit the mode button shows the radio, hit the set button it shows the am band, hit set button it shows the weather station, hit the set again and it will show the IPone or IPod. As long as the phone or ipod is on and hooked up.
    Current Ride
    2015 RT-S SM6 Cocaine
    Pearl White
    Diamond R Web Armrests
    Shorty Windshield
    Previous Ride
    2012 RT SM5 The Beast
    Pure Magnesium Metallic
    Question: Did you read your manual yet?
    It's an easy thing to hook up, and is clearly covered...
    Faribault, MN
    Bob, is it not covered in your Owner's Manual? (Page 39)
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    Jun 2015
    Georgetown, KY
    Thank you for all the good advice. I have the Ipod Nano 7th generation so I can only get AUX mode.
    Does anyone know if a 30 pin adapter to lighting will make it show in iPod mode? Just wondering before I go out and buy one.
    Thank you!
    Nov 2014
    Rural Hall NC
    Quote Originally Posted by bobgeorge View Post
    Thank you!
    Yes it will, as long as it is an Apple adapter or an off brand that will transmit data as well as charge. Most of the off brands will only charge. I use an Apple adapter and it works on my IPhone 6 and IPad.
    Current Ride
    Pearl White
    Shorty Windshield
    Previous Ride
    I gather that you've been plugging into the earbud jack...
    Does your RT have a USB connector? If it does: use your Apple cabling that you would use to hook it up to your computer, and plug it in!
    If it doesn't: get an Apple adapter, and use that to plug in to BRP's IPod cable.
    Very Active Member bronzeflex42's Avatar
    Sep 2014
    Sandersville, GA
    Default MP3
    I have an MP3 player. I plugged the adapter cable that came with the bike, into the plug in the trunk. Bought me a longer cable to reach the glove box. I bought me a female coupler to connect both cables. I keep my MP3 player in the glove box, as i ride and set the radio to AUX and woohlah music all day long.
    2012 Spyder RT Limited Lava Bronze (Psalm 27:1;Luke 12:4,5)
    Jun 2015
    Georgetown, KY
    Quote Originally Posted by bronzeflex42 View Post
    That sounds like a long cable you have
    Jun 2015
    Georgetown, KY
    Yes, I was using the earbud jack.
    I ordered a Apple adapter online and will try it when it comes in
    Jun 2015
    Georgetown, KY
    Got the adapter and it recognized iPod mode. Thank you all for your assistance!
    , and thanks for letting us know that everything is working as it should!
