Results 1 to 11 of 11
    May 2016
    Red Deer, Alberta, Canada
    Default Void Warranty - 2015 ST L
    Will I void my warranty on a 2015 ST L if we install the BRP hitch ourselves?
    And tow a trailer not made by can am?
    I see a lot of people tow different trailers and have after market hitches.
    Anyone run into flack from Can Am with warranty issues? Thank you.
    Pam
    Pam
    2020 F3 T
    I like nonsense, it wakes up the brain cells.
    Fantasy is a necessary ingredient in living.
    Dr. Seuss
    2020 F3 T - Liquid Titanium
    Previously owned
    - 2015 ST L
    - 1997 Suzuki Marauder VZ 800
    2015 ST L , Denim - matte
    Active Member Huked's Avatar
    Mar 2017
    Watford City, North Dakota
    Quote Originally Posted by Gilda View Post
    Pam
    A warranty can't be voided buy what you install. A dealer has to prove whatever part you added caused the damage you are trying to have covered by warranty. If they can prove it was your part, then they can deny that claim, but your warranty is still valid.
    2019 RTL
    Farkles
    BRP Comfort Seat.
    Foam Grips
    Lidlox
    BRP Passenger armrests
    Baja Ron Anti sway bar
    Lamonster's upgraded BRP vibration damper.
    2019 RTL , Asphalt Grey Metallic Dark
    Default WARRANTY
    Quote Originally Posted by Huked View Post
    NOT TRUE ...... If you install it up-side down it will ... .......sorry I couldn't let that pass ..... Mike
    Jun 2010
    Las Vegas
    I believe if your dealer installs the BRP hitch you get a warranty on it but if you install it yourself and it doesn't work you don't get the same warranty. As for pulling a nonBRP trailer Huked is correct that they would have to prove that the trailer was the cause of the issue that you want warranty coverage on.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Bossier LoUiSiAna
    Wow Mike you are usually the first one I see to educate the curious about the Moss-magnum act, I know I learned about it from reading your postTHX
    fyi
    https://en.m.wikipedia.org/wiki/Magn...s_Warranty_Act
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Default WELL REALLY
    fyi
    Some folks here claim I'm waaaaaay to serious , so I was just trying to add a bit of HUMOR ..... hence the emoji .... Thanks for adding the link ..... I knew someone would ...... Mike
    May 2016
    Thanks for the link! I appreciate it!
    Pam
    Pam
    2020 F3 T
    Dr. Seuss
    Previously owned
    - 2015 ST L
    May 2016
    Thank you for the info guys.
    I was told conflicting info so i knew I'd get it straight here.
    Mike, I expected a comment from you. LOL!!
    I'll TRY not to put the hitch upside down.
    Pam
    Pam
    2020 F3 T
    Dr. Seuss
    Previously owned
    - 2015 ST L
    Feb 2017
    Pam
    Tiny little hint - if the ball points toward the ground, it's probably not quite right.
    Jul 2013
    Marietta, GA
    Default Original Poster Is in Alberta Canada
    ????? Different rules may apply in Canada ???????
    Idaho
    Pam
    Ignore all the recommendations and comments above, except maybe SpyderAnn's. You're in Canada. Our rules don't mean nuthin' up there! You'll have to research Canadian warranty laws for yourself unless someone up there responds with good info.
    2014 Copper RTS
