BRP Cover doesn't last too long..
Just a heads up in case anyone was thinking of buying a full cover from BRP; Don't do it!
After less than two years, the cotton inside has decomposed, leaving a fine layer of hard to remove lint every time I remove it.
You must have got a bad one. I have had mine for around 5 years on 4 different Spyders, and although it has faded it is still in great condition inside, and yes it is an outside cover.
We now have His and Hers Spyders.
Current Spyder, 2015 F3 Steel Black, Passenger Backrest, Blue Ridge Screen with Xcreen Extention, Akrapovic Muffler, Attitude Handlebars, Blades front rims, RT Swaybar,
Her Spyder 2011 Magnesium RSS Sportrack and Backrest, Comfort Seat, Grip Puppies, 3.5 inch Riser Bars, Wespyd Signature Swaybar. Hindle Muffler, Godiva Screen, Hiway Pegs Can Am Panniers
Previous Spyders
2013 ST SM5
2011 RSS
2010 RS
I have one also from 2010 and it seems as good as the day I got it but I will admit that I don't use it often. It sits in my garage in Las Vegas which gets really, really hot but it hasn't decomposed.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
After the inside cotton had started to peel away around areas that they're shouldn't be any (exhaust, rubber tires),
I actually took the time to peel that damaged layer off, and run it through a light dryer cycle to remove any loose fibers, so they wouldn't stick to the bike. All to no avail.. $229 down the drain for another BRP POS.
Any suggestions for any other replacement outdoor one?
I've got one from 2010 also: it's still like new!
You put it in a HOT dryer????? "You have discovered the enemy and he is within"
Jack!
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
Jack!
You're probably right, but it was my last resort! (And it was on the lowest setting..)
