Any Gear Heads in CT
I was wondering if there are any gear heads in CT who could give a lesson or pointers on doing regular maintenance like oil changes. I'm a hands on learner so the instructions don't help me out. I want to cut down on the expensive dealer visits, they are great but I want to do some things myself. Thanks guys
You have to watch video's- Read the manual- And Most important take of the Tupperware a few times yourself and before you know it you will be doing your own maintenance. There is NO easy route.
Sea Doo GTI-SE 90 Jet Ski!!
Watch these videos and if you're the least bit mechanically inclined it will be a breeze.
https://www.youtube.com/watch?v=ZPeb1YqV4Gw&feature=youtu.be
Anytime Dan. Whatever you need
JIM EVANS
2014 RTL, cb,all panels color matched over 300 LEDs, pass armrests sat radio chrome WS brkt, larger w.s, more to come
I'd like to see best ways to remove the plastic without breaking clips. Kinda scary to do for first timer. Also I wish I could join you on ride tomorrow but can't visiting all the family. Do you have week days off?
I work during the week. We can get together some time. Have taken mine apart several times 😂
JIM EVANS
https://youtu.be/NReoHtqs70Q
You seem to have an RT and this is the 1st Step -getting the mirror off!
After that your owners manual tells you how to do each piece and if you want to write down how many screws for each piece and even do a little drawing if you want to. It really is just doing it a few times and you will be a Pro!!!
Update I have just performed my first oil change and a headlight repair...apparently the previous owner was nice enough to instal hid lights and a connection had juat came loose. I am astonished how much work it took. This engineers are sadist i think. But everything went well. Striped the 6mm drain plug a little and replaced it with a new one. Thanks for all the help and tips everyone.
